check engine light?
Old Aug 29, 2010 | 06:55 PM
jkarne's Avatar
jkarne
check engine light?
my check engine light came on while i was traveling from wash. state to southern cali. I stopped in a shop at oakland and the code was p2004 which is a code for an intake manifold control valve bank one. I have a 2004 5.4 liter 3 valve, which in my chiltons manual says that it don't have one of these valves! so does anybody have any idea if it has one or not? and what would the fix be if it does?
Old Aug 29, 2010 | 08:27 PM
bridge's Avatar
bridge
Sick 'n Tired
Intake manifold runner control (IMRC) stuck open bank 1.
Possible causes:
-IMRC short
-Damaged IMRC solenoid or actuator
-Block vacuum hoses
Check your hoses for crimps.
Old Aug 30, 2010 | 01:38 PM
jkarne's Avatar
jkarne
where exactly is all this located and will it hurt my truck to drive it for a while if its bad.
Old Aug 30, 2010 | 05:30 PM
bridge's Avatar
bridge
Sick 'n Tired
Your engine has a number of vacuum hoses located, well, everywhere. Look under your hood and make sure none of them are crimped, spilt, blocked or disconnected.
If you don't find one then your problem gets exponentially worse. Not catastrophic, just more complicated.
Old Aug 30, 2010 | 10:57 PM
jkarne's Avatar
jkarne
thanks! i checked after work today and i didn't find anything, but thats not saying i didn't miss one. I guess the next step is to pull the intake manifold off of it. is there anything else i should do to it while i have it off? maybee clean the maf sensor stuff like that?
mike yates
1983 - 2012 Ranger & B-Series
43
Oct 1, 2012 03:57 PM
norconut
Apr 23, 2012 01:35 AM
Vin Man
2004 - 2008 F150
Jul 9, 2009 12:08 AM
1984F15016
Jan 23, 2008 05:55 PM
dcale101
30
Nov 19, 2004 06:05 PM
