Scratch built courtesy lights?
Old Aug 29, 2010 | 05:22 AM
karatedavid's Avatar
karatedavid
Has anybody attempted this? I’d really like to get a plunger switch or something so when I open the doors the dome light would come on. Anyone have any idea on how much work would be involved in this, and where I would splice the wires? What kind of switch for the door??? None of the dents at the salvage yard appear to have this, so I haven’t been able to any ideas on this.
My truck is the Custom Trim package...so that really means it came with dittaly squat comfort wise.
Help’s always appreciated!!!
Old Aug 29, 2010 | 05:44 AM
75Three90's Avatar
75Three90
i guess the easiest wa in my eyes is to find an 80's model and yank the wiring and the plunger from it and install it on your truck shouldnt bee that hard, but my 1979 has a light in it my grandpa put in it out of an '84 lol
Old Aug 29, 2010 | 06:47 AM
mkdubs's Avatar
mkdubs
Karatedavid, you mean that when you open your door, you dont have a dome light that kicks on? My truck 79' f150 ranger has 2 door plungers one on each door and anytime there opened the dome light kicks on. I know you can get those at autozone, there just like a brake light switch. mine have 2 prongs on the rear, one hot, one hot when plunger is released. Run constant 12v to the plunger,and the other to a courtesy light and when you open the door it will complete the circuit and the light should come on. I hope this is what you were talking about if not please delete this post, im really exhaust but cant seem to sleep.
Old Aug 29, 2010 | 09:14 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The trucks came with a factory installed switch in each door jam to do that. Here is the illustration from the parts manual showing the switch. It screwed into the door jam and plugged into the dash wiring harness.
Check basic p/n 13713.
Even if you don't have the switches, the wiring harness should have the plugs for them.
Ford p/n D3TZ-13713-A, Motorcraft p/n SW-1161
Click on the .pdf link to view.
File Type: pdf
Old Aug 29, 2010 | 12:25 PM
tbear853's Avatar
tbear853
Thumbs up
Yeah, my '77 has the plungers and I used some chrome plated steel trailer tag lights for courtesy lights, one each end of the dash down low. Of course mine have regular bulbs ... but I see that now you can get the same exact ligfht in LED versions.
I removed the white plastic insert in mine, makes bulb changes easier but I've never needed to yet in 20+ years.
Optronics Trailer Lights - LPL31CB
LED Mini Trailer License Plate Light, 2 Diode - Chrome Plated Optronics Trailer Lights LPL31CB
Old Aug 29, 2010 | 04:22 PM
karatedavid
After looking at the door jam... AND...feeling like a total idiot I realized I do have the plunger switch and the wiring harness. I unscrewed the switches and discovered why there not working... those poor little suckers are rusted and corroded as hell... definitely not salvable. I'm going to see if some of the catalogs have a replacement part... or just run down to napa or o'reilys and get a new switch. Me getting under the dash made me a little bit enthusiastic about getting some more lights in there in the future.
Thanks guys!
Old Aug 30, 2010 | 12:05 PM
George Frasier's Avatar
George Frasier
Severalyears ago, I added the "map light" from a 70's pinto to above the drivers door. The light switches on when it's extended and is adjustable for angle ( front-rear & up/down) Very minor trimming and paint to match the interior + 2 small screws - nworks great for map reading or funny books.
Old Aug 30, 2010 | 01:02 PM
mark a.'s Avatar
mark a.
I had long since forgotten about the Pinto map light, those were cool.
Old Aug 30, 2010 | 06:02 PM
George Frasier
Mark A. - YES - neat / compact + can be mounted almost anywhere. I have a fiberglas canopy = cleaned 2 spots w/ acetone - mounted 2 "home-made fiberglas circles and installed truck back-up ligfts inside the canopy./ Both can be switched on, and the back one can be turned on as the back window is raised by using a mercury (home AC) switch < like a light under a hood o trunk of a car.
Old Sep 5, 2010 | 05:39 PM
ptalbert33's Avatar
ptalbert33
Anyone know the actual bulb size for the Dome Light? I have a 1974 F100 and when I picked it up the bulb was not in it.
Old Sep 6, 2010 | 11:09 PM
karatedavid
I couldn't find the bulb when I need to replace it. I'm sure it's out there...
Old Sep 8, 2010 | 05:52 AM
Friesian-Bronco's Avatar
Friesian-Bronco
Any trucks from this era come with that? an option maybe?
Mine don't, and if nothing factory is available to get for it, might have to do just that and get one of those tilt switches and make one...
G.
Old Sep 8, 2010 | 05:48 PM
George Frasier
Hood light ?
Neede a hood light that turns on when th hood is opened ? Try getting a trunk light. These cane on a LOT of cars & should be availible at most any "pull-n-save". OR 1 can be made from a mercury switch and a stop light bulb, along with a bit of "imagineering". OR use an interior "courtesy light" usually just inside the door / under the dash. << just a few ideas to 'play' with.
Old Sep 8, 2010 | 06:07 PM
HIO Silver's Avatar
HIO Silver
Hood Light Source
Late 80s and early 90s Broncos came with an underhood light.
I have two of them awaiting installation for each side of the engine plus alot of other wiring to do - auxiliary back-up floods, 100w offroad lights, Bosch fogs, air horns, and wheel well lights. 'been gathering fused links, junction posts, and plastic look wraps from mid 80s to early 90s F-bodies (Camaros & Firebiord/TAs) are a good source.
If I were to install interior courtesy lights, I'd look into early Mustangs and their interior "convenience" group items.
Old Sep 9, 2010 | 02:28 AM
Friesian-Bronco
Good to know, I'll have to grab one from a later truck if i can find one, next time to the salvage yard..
That list sounds familiar... I have LED backup and tail lights, fog lights all waiting to be put in, ordering the offroad lights soon(2 front bumper, 4 roof..), and i got 1air horn setup installed(plays dixie) and want to do another louder semi style one too.
But I must say, I've never heard of wheel well lights.... as in, In the wheel well above the tires? What for?
I'm thinking about just getting another set of the 2" LED backup lights to mount for courtesy/dome lights, one on each side of the cab, but I want to try to find a ball/swivel mount for them if I can.
G.
