Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 Escape Engine Light On P 0301 Code
Old Aug 28, 2010 | 03:51 PM
Keri's Avatar
Keri
Just purchased a 2001 Escape for my daughter. Had it aligned and picked it up. When I left the parking lot the Check Engine LIght was on and the engine was misfiring a bit. Checked the code at A/Z it was a P 0304 in Cylinder 4. (V-6). Total novice at this... any suggestions?
Print out said:
Ignition system fault - spark plugs, Ignition wires, coil
Vauum leak
injector fault
high or low fuel pressure
Ran the engine at idle, revved it to 4000 RPM and felt the misfire periodically.
Keri
Old Aug 28, 2010 | 06:46 PM
martin_csr's Avatar
martin_csr
I'd guess you need a new coil for the suspect cylinder... not sure which one is throwing the code...
P301 is in the title (cylinder #1), but P304 is mentioned in you post (cyl #4).
Old Aug 28, 2010 | 06:48 PM
wptski's Avatar
wptski
Swap the coil to see if the misfire moves also.
Old Aug 28, 2010 | 08:49 PM
bmuhlbach's Avatar
bmuhlbach
this is what mine did.In the morning or humid weather it would run really rough then clear up.I found the egr vacuum line on the back of manifold was bad and the lower intake gaskets.Don't know which fixed it but no issues in over 1 1/2 years
NOWAYBUTUSA
1983 - 2012 Ranger & B-Series
May 16, 2015 06:24 PM
ranger_xlt39
Apr 15, 2015 07:02 AM
jpfont
Oct 16, 2014 06:58 AM
2001Escape123
May 31, 2014 07:22 AM
TheGageinator
2004 - 2008 F150
Mar 7, 2014 12:14 PM
