Duraspark help?
Old Aug 28, 2010 | 02:14 PM
0351mike's Avatar
0351mike
Duraspark help?
Hello all, I could use some assistance.
I have a 75 F150 with a 302 in it. I just put a cam, lifters, oil pump and water pump in it. The truck fires right up but after I drive it and then turn it off- it wont start until it completely cools off. When I try it almost sounds like the motor is timed incorrectly. The motor turns slow, and the battery acts like it is dead. When it cools it starts without hesitation. It is timed correctly and is very responsive when cool. I am trying to figure out which part in the ignition system is overheating. I replaced the control module and it still does it. Where should I check next? I have had several of these trucks so I have most of the parts on the shelf to interchange.
Old Aug 28, 2010 | 02:43 PM
tinaheels's Avatar
tinaheels
how old is the starter ?
Old Aug 28, 2010 | 03:26 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
X2 plus how is the condition of your battery/ starter wires?
How old is the battery? And do you know how well the alternator is charging?
Josh
Old Aug 28, 2010 | 03:40 PM
0351mike's Avatar
0351mike
components
battery is new, starter is new, cables are new. The altenator is older, but I guess if I am getting 12v back out its good? How about the voltage reg- could this cause the battery to act dead?
Old Aug 28, 2010 | 03:50 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Get a voltmeter and check your battery voltage with it running. If the voltage is LESS than 14.5 volts there is a problem with either the alternator or the regulator.
Old Aug 28, 2010 | 03:51 PM
Bullitt390's Avatar
Bullitt390
Alternator should be putting out 13.5+ at RPMs above idle.
I would have the alternator and regulator tested and also check the wiring harness for any corrosion, breaks or bad plugs.
Josh
Old Aug 28, 2010 | 07:26 PM
v8only's Avatar
v8only
is the starter getting heat soaked poss from longtube headers?
Old Aug 29, 2010 | 06:11 AM
DKW 86's Avatar
DKW 86
Was thinking it was a header related heat problem myself. Heat shield on the starter?
Old Aug 29, 2010 | 08:49 AM
rdweathers's Avatar
rdweathers
If the problem just started after you changed out the above mentioned parts, i would think it is still timing related although you said it was correct, if the timing is to far advanced and it is hot it will give a similar symptom as you described.
Old Aug 29, 2010 | 09:36 AM
0351mike's Avatar
0351mike
problems
I am running stock exhaust manifolds and I think the clearence is good on the starter. This truck has been a project from the get go and really has never reliably ran. But this issue is new. I will test the battery and voltage reg this morning. But I keep going back to the timing- I was alway taught that you can throw the timing specs out once you put an aftermarket cam in. It is not radical- just a basic towing cam- 1500-4600 range and moderate lift and duration. I did time it at 6 BTC and it starts right up and is responsive. I was also taught to advance as far as you can until it pings under load and then retard a little. Should I be retarding this now and then check how it starts when hot?
Old Aug 29, 2010 | 10:12 AM
lynn s 460's Avatar
lynn s 460
Hi mike iam thinking its a carb thing it maybe running alittle lean
Old Aug 29, 2010 | 11:10 AM
rdweathers's Avatar
rdweathers
I was taught the same way for timing, i have a 67 Chevelle SS 396 with a radical cam, and it is timed this way. It has been timed this way for 20 years. When hot if it stalls on spinning over back the timing off a little untill this goes away.
Old Aug 29, 2010 | 11:30 AM
0351mike's Avatar
0351mike
F(ound) O (n) R(oad) D(ead)
Ok- getting 14 volts at battery- swapped out the coil and condenser and brain box- retarded the timing a few degrees- defintely not as responsive. Starts right up - drove it for a few miles- parked it- turned it off and tryed right again- it starts. gave it 5 minutes and no start?????
Old Aug 29, 2010 | 11:53 AM
arctic y block's Avatar
arctic y block
If you are sure the ign coil and brain box are good than what is left but the starter or low voltage.?
Old Aug 29, 2010 | 09:45 PM
gus11208's Avatar
gus11208
I learned just because your starter is new doesnt mean its good. I had purchaced so many "NEW" parts from the auto parts place only to find out that there crap. I just replaced my starter that was 3 months old how about that for quality control.
vote for me
2010 FTE '61-'79 Classic Championship Round-8. - Page 4 - Ford Truck Enthusiasts Forums
