Ts chip ERRRR!!!
Old Aug 26, 2010 | 10:36 PM
7.3 junkie's Avatar
7.3 junkie
Ts chip ERRRR!!!
Well I was really excited today when my ts chip showed up onthe front porch today. Not so excited after installing it my truck wouldnt start. It would crank for days and glow plug light was on at all times. I had a dp tuner 5 chip it my truck last week and ran great tons of power so i decided to give my bubby his chip back and buy my own. Well I had him come over with his truck a no luck as well sell the cel on his and would crank for days. Do you think i got a fualty chip or just the wrong programming???? CLEANED it several times following the directions
Old Aug 27, 2010 | 04:31 AM
drivembig's Avatar
drivembig
I'd say a bad chip. Send it back and get it replaced. Does the truck fire and run correctly without the TS installed?
Old Aug 27, 2010 | 10:59 AM
strokin'_tatsch's Avatar
strokin'_tatsch
I don't think your getting the chip set just right on the J3 port..
Old Aug 27, 2010 | 01:14 PM
Talyn's Avatar
Talyn
That or he over cleaned one of the terminals and there is no more gold left to make the connection.
If he had a DP on already, he wouldn't have had to clean the terminals.
Old Aug 27, 2010 | 01:59 PM
Brown Falcon's Avatar
Brown Falcon
I was thinking the same thing William. Might need to re-solder the terminals on the ECU.
Old Aug 27, 2010 | 02:03 PM
Neal 97 250's Avatar
Neal 97 250
I don't think it is his terminals. Ya'll remember he said he put it on his buddies truck and still nothing.
Bad chip IMO.
Old Aug 27, 2010 | 02:08 PM
Brown Falcon
Well when you put it that way Neal... That makes too much SENSE!
Old Aug 27, 2010 | 06:35 PM
7.3 junkie's Avatar
7.3 junkie
Well I found out problem called the company where i ordered the chip. My truck is a cali truck and its pcm is mme3 so the chip didnt have the right program so... I sent it back this morning for the reprogram on the chip and said it will be as good as new!!!
Old Aug 27, 2010 | 07:16 PM
strokin'_tatsch
That would cause an issue. Usually helps to give the right PCM code. Glad you got it all figured out! It's not very often we hear of TS chips being bad so I didn't figure the chip was bad. Thanks for coming back to tell us what you found out. Have fun with your chip when you get it back
Old Aug 28, 2010 | 09:02 AM
Talyn's Avatar
Talyn
Excellent. !=)
MPannell
Apr 27, 2016 01:07 AM
tjbradney
20
Apr 10, 2016 03:59 PM
tjbradney
Jan 17, 2016 01:32 AM
dcelrod
Sep 11, 2015 07:56 PM
Dstosh
Jul 26, 2015 04:22 PM
