Getting a dptuner, need suggestions.
Old Aug 27, 2010 | 03:27 PM
duck fan's Avatar
duck fan
Because racetruck
Yes, the decel works better on the manual trucks IMHO. Since you don't have TC slip, when the tune closes the EBPV you get even better engine braking
Old Aug 27, 2010 | 03:36 PM
Mr. Finch's Avatar
Mr. Finch
O.k. that makes sense, I thought it just kept the converter locked longer on auto trannys to aid in engine braking.
Old Aug 27, 2010 | 03:43 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
The decel tune includes AT tuning for TC lockup, line pressures, etc. It works well! Towing my 25' 5er I can descend an 8% grade with almost no braking.
Old Aug 28, 2010 | 05:05 AM
kbeefy's Avatar
kbeefy
13.5 unloaded is alot low for a stock truck. I was able to get 19 from mine before I modded it.
Edit: I get 10mpg towing the setup in my sig.... 23k combined, at least 15k over stock (3x stock)
Old Aug 28, 2010 | 10:47 PM
Mr. Finch's Avatar
Mr. Finch
Yea I am not happy with that mpg either, I bought it expecting better than my old 302, but right now $ per mile they are about the same. But it is not stock, from what I see it has the bankd "power pack" minus a chip/tuner, but it gets NO boost. May have found the prob, drivers up pipe is clean except for a spot on the head about the size of half of a $ bill.
Old Aug 29, 2010 | 01:33 AM
aawlberninf350
It's a Van Gogh
Up pipe leaks are bad all around. Bit of a PITA to get in there, but worth it. I used the cheby donuts, Felpro #8194, much better seal than the stockers. And while in there (assuming you remove the turbo rather than doing the donuts from below) great opportunity to do other maintenance or upgrades, all of which should happen before a tuner.
90pioneer
Feb 10, 2013 02:19 AM
00Dave
23
Sep 14, 2008 06:27 AM
erik_bishop
22
Apr 14, 2007 06:49 PM
jtharvey
22
Feb 18, 2006 08:43 AM
LaredoF350
Feb 5, 2005 06:11 AM
