head swap
Old Aug 25, 2010 | 08:33 PM
longblane's Avatar
longblane
head swap
i am needing to know if a head from a 1992 f-150 FI inline six 4.9l will work on a 82 f-100 4.9l carburated inline six. here r the vins. if anyone has an anwser or a away to find one pleae let me know.
f-150 vin/ 1FTDF15Y5NNB05356
f-100 vin/ 2FTCF10Y1DCA21669
Old Aug 26, 2010 | 01:38 AM
Ranger GT2's Avatar
Ranger GT2
You would better off using a head off of an old motor. Something 85 or older.
Old Aug 26, 2010 | 07:34 AM
f100jim's Avatar
f100jim
Technically, they interchange. The '92 head will be the fuel injected head. It will give you a little more compression, and it is the "fast burn" chamber design, so you would need to back your ignition timing down a few degrees. IIRC, the '92 head uses different rocker arm studs and the rockers are adjustable compared to the '82 rockers that you just tighten down to the stop. You would have to use the ,92 rocker arms and would have to adjust them properly.
Another thing to consider, the FI heads are more prone to cracking. I have no personal experience along these lines, but I have heard stories from guys who when to the junkyard for a FI head, got it home and cleaned it up only to discover cracks.
If you have a good FI head on hand, it will work. If you are shopping for a head, look for an older head from a carburated engine.
Old Aug 26, 2010 | 10:15 AM
AbandonedBronco's Avatar
AbandonedBronco
F100jim said it all.
Old Aug 26, 2010 | 07:46 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
I thought the EFI head used pedestal rockers?
Old Aug 30, 2010 | 09:02 AM
f100jim's Avatar
f100jim
I think you are right.
phoskins
Jan 12, 2015 08:20 PM
ididntdoit89
Dec 7, 2014 03:12 PM
KsCop
Jul 14, 2014 11:56 PM
USMC0351fordtruckin
24
Jul 24, 2013 07:05 PM
Bob Thompson
Aug 4, 2003 11:09 AM
