E4OD Slips into 1st gear?
Old Aug 25, 2010 | 06:37 AM
presidentsdad's Avatar
presidentsdad
Hey all....I've never owned an automatic transmissioned vehicle. I now have a 96 F250 with the E4OD. It seems when I lift off of the brake and transition to the gas that it takes just a bit for the truck to start to move forward. Maybe it's more of driveline slack? It feels like the drive shaft has to "shift" back to the rear differential and then begin applying power, rather than already being there and just applying power.
All that for this: Is this operation normal?
Old Aug 25, 2010 | 08:29 AM
DBGrif91's Avatar
DBGrif91
About how long would say the delay is? A slight delay [less than a second] could be considered normal, but a longer delay [longer than a second] could be indicative of a bad TPS or other sensor.
Old Aug 25, 2010 | 10:37 AM
presidentsdad
I'd say it's one second or less, more of a "clunk" really.
Old Aug 25, 2010 | 11:05 AM
rla2005's Avatar
rla2005
Sounds perfectly normal to me. There is an inherent amount of drive line slack that causes that "clunk" you are referring too as well as a time delay from the time you move the lever out of Park/Neutral into Drive/Reverse.
Old Aug 25, 2010 | 01:41 PM
presidentsdad
I know about that sort of slack. I'm talking about coming up to a red light and stopping, there's a slight "clunk" and then resuming my trip from the green light there's a slight pause and soft "clunk" upon movement.
Old Aug 25, 2010 | 05:07 PM
rla2005's Avatar
rla2005
I have been thinking about this one. Other causes of noise are bad u-joints, excessive play between the ring gear and pinion. Worn spider gears, axle shaft splines, limited slip clutch plates.
Another item to check with minimal effort is the drive shaft slip joint. It can cause symptoms such as vibration or clunking. Easiest way to check is to remove the drive shaft then pull it apart, lube it with a good quality grease then re-assemble. Pay attention to the "clocking" of the u-joint knuckles, best advice is to mark the pieces before disassembling.
z31freakify
25
Apr 3, 2026 02:58 PM
Seattleslow
Mar 3, 2017 12:22 PM
Blind Driver
Feb 29, 2016 11:43 AM
NunchuckNorris
Sep 7, 2015 07:03 PM
trackenator
Oct 16, 2009 05:55 PM
