Cruise control
Old Aug 25, 2010 | 01:50 AM
oem78's Avatar
oem78
Cruise control
Anybody have a 1979 f150 with Factory cruise control on the steering wheel with a fixed steering(non-tilit) colunm and a 4spd tranny.
I have a 1979 F150 4x4 with the np435 tranny and a fixed steering colunm and would like to add the factory cruise control, but did ford make any trucks like this. don't wnat to have an odd truck.
Old Aug 25, 2010 | 12:36 PM
steponit's Avatar
steponit
They didn't put speed control on standard transmission vehicles back then
Old Aug 25, 2010 | 02:20 PM
oem78's Avatar
oem78
Was there a dealer add on for standard transmissions??
Old Aug 25, 2010 | 04:03 PM
steponit's Avatar
steponit
Not that I know of
The transmission wouldn't be able to shift up or down when it needed to
Old Aug 25, 2010 | 04:25 PM
dynamic's Avatar
dynamic
I have a 84 mustang with a 5 spd and cruise control. When you want to shift you have to disable the cruise.
I cant see why you cant make it work. Find a cruise control column and gut it. Modify as needed and re-install in your not cruise column.
This is exactlly what I plan to do with my short bed unless I can find a tilt column to do this with.
I already have an auto shift column with the cruise and tilt that I am gonna use for parts. I need to find a tilt coulmn for the 4 speed now.
Old Aug 25, 2010 | 04:43 PM
steponit's Avatar
steponit
No one said it is couldn't be done, I just answered his questions
The column has nothing to do with speed control.
It is controlled by all the wiring,special brake pedal assembly/booster,etc
Old Aug 25, 2010 | 04:52 PM
ranger429's Avatar
ranger429
Good luck. I made my own so I didn't have to pay out the ying yang for one.
Old Aug 25, 2010 | 04:56 PM
dynamic's Avatar
dynamic
OK... I will bite... how did you make your own?
Delete the shift lever from an auto shift column?
I have spare columns to take parts from!!!
Old Aug 26, 2010 | 07:14 AM
doug70's Avatar
doug70
pictures, list of matirials
Anybody got a list of materials... do do this? I am converting my 73 to a 4x4 standard and want to keep my cruise control.
Doug
Old Aug 26, 2010 | 11:49 AM
steponit's Avatar
steponit
If you already have Speed control then you don't need anything except for the clutch and brake pedal assembly
Old Aug 26, 2010 | 11:53 AM
doug70's Avatar
doug70
That what I thought, but it sounded like I might loose something when I changed out the existing brake pedal.
Doug
Old Aug 26, 2010 | 04:33 PM
steponit's Avatar
steponit
What model is your 73 ?
I'll ask someone what you need to make it work
Old Aug 27, 2010 | 10:14 AM
doug70's Avatar
doug70
Ranger
It is a Ranger XLT F100.
Doug
lightninquick
Dec 15, 2011 04:08 AM
75styleside
Mar 28, 2011 02:02 AM
66gpw
Apr 26, 2006 10:57 PM
aserock
Nov 24, 2005 11:57 AM
mep123
Electrical Systems/Wiring
Oct 23, 2003 07:31 PM
