1978 - 1996 Big Bronco
1990 bronco diff info needed
Old Aug 24, 2010 | 10:11 PM
vtjvt's Avatar
vtjvt
hey everyone. Just a couple of quick questions I am assuming my rear diff is the 8.8?. I am going to drain and inspect everything before the elk hunt this year, My question is do I need to add friction modifier when I refill or not? And is 80/90 gear oil ok to use?
Old Aug 24, 2010 | 10:41 PM
Encho's Avatar
Encho
The Southernmost Mod
Read the tab on your door, the codes should specify if yours is a L/S... i'm not sure what you should be looking for (as for the letter code), but if it isn't a L/S it won't need friction modifier. The proper oil should be specified in the Owner's Manual (I searched, it's 80w90 allright).
Old Aug 24, 2010 | 11:00 PM
vtjvt's Avatar
vtjvt
Thanks, I will check the door tag and see what I can figure it out, If not I guess I can just wait till the cover is off and look for myself.
Old Aug 25, 2010 | 08:46 PM
greystreak92's Avatar
greystreak92
The axle tag will also tell you if you have the LS or not. Since you are under there anyway look for an "L" between the ratio numbers.
hharris8
Sep 5, 2016 09:49 AM
Sharkster54
Apr 17, 2016 08:58 PM
Ford938
Dec 29, 2013 08:13 PM
Fordpup
Bronco II
Aug 8, 2008 10:01 PM
Tdvjensen
Apr 13, 2006 11:31 AM
