Steering oil?
Old Aug 27, 2021 | 06:39 AM
624WD's Avatar
624WD
This is the semi-fluid grease I use…
Chevron Delo EP 00 semi-fluid grease.
This is a superior, synthetic semi-fluid (self-leveling) grease for all vintage steering gear applications. Its specs exceed that of the commonly used Champion “00” and Penrite Semi-Fluid Steering Gear Fluid from Australia (which surprisingly at manufacturer stated 18 pounds, doesn’t meet EP minimum standard of 40 pounds for Timken OK Load test, per ASTM D 2509). The base oil viscosity is equivalent to 90 weight gear oil, which was the original spec for many vintage steering gearboxes. It will flow somewhat better than the commonly used John Deere “Cornhead” grease, which is NLGI 0 rated. It should not leak as does 90 weight gear oil from vintage steering gearboxes could in normal condition and operation.
Old Aug 27, 2021 | 09:31 AM
hiball3985's Avatar
hiball3985
Originally Posted by ibuzzard
Grease, not oil, is the appropriate lubrication for your steering box. Many people have assumed, incorrectly, that gear oil would be correct, and leaking is the result.
He asked about the box in his 1960, don't know why he posted it in this section. That box uses oil according to all FORD shop manuals.
Old Aug 27, 2021 | 09:38 AM
hiball3985's Avatar
hiball3985
Thank you for that info. I think I'll try it.
Old Aug 27, 2021 | 10:12 AM
hiball3985's Avatar
hiball3985
Originally Posted by Mixplix
I appreciate the input. I had a guy rebuild it. He used the appropriate 90wt oil. It now leaks. I am considering my options. How bad would it be to use the 00 grease instead of 90wt oil?
Were is it leaking?
Old Aug 27, 2021 | 07:48 PM
1954F100ranger's Avatar
1954F100ranger
Anyone have there box/steering shaft out of there truck currently? I need to know how long the exposed shaft is from the flange where it comes out of the box to the very top tip of it where the steering wheel bolts to it... and is the shaft made of a hollow tube that the horn wire runs through? I may have a 1961 box mixed in with my 1953-56 parts. Thanks guys
Old Aug 27, 2021 | 09:24 PM
fivestarmmd's Avatar
fivestarmmd
A 61-64 is a solid shaft , as far as lenght I would have go out in pasture and dig around .
Old Aug 28, 2021 | 04:46 PM
1954F100ranger
@fivestarmmd Do the horn contacts work like an old Falcon or Mustang/
Old Aug 28, 2021 | 04:56 PM
fivestarmmd
Uses brushes one under horn button and one in turn signal switch.
Old Oct 28, 2021 | 10:30 PM
Red60's Avatar
Red60
Horn brush
This thread came up in a horn search and has good info. Does anyone have pictures of the horn brushes? Both above and below the steering wheel? The diagrams are great but I can’t picture how its supposed to look. My truck has nothing under the horn button except a spring.
Truck is a 1961F1004x4
Thanks
Old Oct 29, 2021 | 07:52 AM
fivestarmmd
Look up C20Z-13A821-A
Old Oct 29, 2021 | 07:15 PM
Red60's Avatar
Red60
That brings up good results thanks!
flyyboy
May 20, 2021 06:17 PM
Mearntain
18
May 18, 2019 11:12 AM
newguy399
Dec 19, 2013 09:54 AM
51FordTN
May 20, 2013 06:57 PM
green53
Apr 9, 2010 01:29 PM
