Steering oil?
Old Aug 24, 2010 | 08:27 PM
flipklos's Avatar
flipklos
Steering oil?
What is recomended for a steering gear lubricant on the 64 and earlier steering box.
I found molly grease in there. I see that is an inefficent lube as it has no way to flow into contact as there is no grease fitting on the box. In my mind a 140W gear oil would be superior as it can flow and travel throught the gearbox and into contact with the mesh area. I even thought of taking some ISO class 600 oil from work and utalizing that as it is EP rated and thicker yet.
Old Aug 24, 2010 | 08:43 PM
66crawler's Avatar
66crawler
I thought they used gear oil, like for a diff or t-case.
Old Aug 25, 2010 | 01:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Steering gear lubricant (grease), not gear oil.
It's available from Ford, comes in a cardboard tube. The tube is placed into a grease gun, then injected into the gearbox.
XG1C (replaced C3AZ19578A) ..Steering Gear Lubricant-Use with M/S gearboxes.
MSRP: $3.43 // PARTSGUYED.COM price: $3.08.
100's of dealers stock this stuff...there's only one page on the dealer locator that lists the sources. There are so many dealers listed on the west coast, I cannot tell you who has any in your area.
Old Aug 25, 2010 | 12:47 PM
66crawler's Avatar
66crawler
Sry N.D. im only 26 and all my cars were power steering.
Old Aug 25, 2010 | 01:52 PM
NumberDummy
What does a power steering gear box have to do with a manual steering gear box?
The OP wanted to know what type of lubricant was used in manual steering gear boxes.
The only vehicles with P/S that used a manual steering gear box were those equipped with Power Assist P/S.
With Power Assist P/S, the gear box has nothing to do with the P/S system.
Old Aug 22, 2021 | 07:01 PM
Mixplix's Avatar
Mixplix
Just to confirm, Bill, you would recommend this for a 1960 f-100?
Thanks...
Old Aug 22, 2021 | 10:03 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
I wish Bill was on here to answer, but he is on hiatus. Motorcraft XG1C is correct for your steering box, it is a grease, not oil.
Edit Note: XG1C has been replaced by XG1E-1
Old Aug 23, 2021 | 05:14 PM
BobbyFord's Avatar
BobbyFord
This is what you want for a manual steering box…
https://www.ecklers.com/champion-00-...-376792-1.html
Old Aug 24, 2021 | 08:54 AM
hiball3985's Avatar
hiball3985
Thanks...
Your 1960 is a worm and sector box and uses oil. 1961 changed to a recirculating ball system and uses grease.
Old Aug 24, 2021 | 03:12 PM
fivestarmmd's Avatar
fivestarmmd
That "OO" grease can be gotton at TSC
Old Aug 24, 2021 | 05:11 PM
624WD's Avatar
624WD
another name for this is - Semi-fluid … grease. If you can’t locate… I have tubes if this for a variety of projects in the works. If you need one let me know. I bought a bulk 5 gallon bucket of the stuff and had it stuffed into tubes.
Old Aug 26, 2021 | 10:51 AM
Mixplix's Avatar
Mixplix
I appreciate the input. I had a guy rebuild it. He used the appropriate 90wt oil. It now leaks. I am considering my options. How bad would it be to use the 00 grease instead of 90wt oil?
Old Aug 26, 2021 | 10:58 AM
ibuzzard's Avatar
ibuzzard
Grease, not oil, is the appropriate lubrication for your steering box. Many people have assumed, incorrectly, that gear oil would be correct, and leaking is the result.
Old Aug 26, 2021 | 11:51 AM
BobbyFord's Avatar
BobbyFord
I have 00 grease in my 63 steering box
Old Aug 26, 2021 | 12:34 PM
fivestarmmd
I have cornhead grease in several ag steering boxes and shredder gear boxes. It melts with movement..Comes in tube for grease gun. John Deere has it.
