FoMoCo Special Steering Gear Lurbicant
What is the modern day equivalent of FoMoCo Special Steering Gear Lubricant? I've tried searching but have had no luck when looking online, I must be looking in the wrong places.
My box on the 64 F100 is leaking pretty good, even with me barely turning the wheel to move the truck in the garage slightly (left a 6 inch diameter spot on the ground by the time I noticed it), so I feel I have no choice to pull it and replace some seals. I know some people said use gear oil, other say absolutely not, so I'm at a loss at what to use. Thanks.
I believe it is still available under the Motorcraft brand, XG1C, was formerly C3AZ-19578-A. Comes in a tube, like caulking. NumberDummy will notice this and give better info, as it has been brought up in the past. It is not a 80 w. or 90 w. gear oil, as some believe. Gear oils will leak right out of dried up old seals.
Sounds good, maybe that's what my issue is then - just simply wrong lubricant in there. What is leaking out is 100% an oil, and not a grease, I'd put money on it being some 90w. Maybe I can get away with just draining it and refilling with the proper lubricant.
Any concerns I should have by doing that (and not changing seals) or possible damage from the gear oil for sitting in there for 30+ years while the truck sat idle in someones garage?
Was just out at the truck and went to pull, atleast what I thought were the drain plugs, but nothing came out. So either I didnt pull the proper bolts or maybe it is grease in there, and not oil as I suspected. I definitely have an "oily" drip though.
I was under the impression from another post I read, that I was supposed to remove both the bottom and top bolt, fill through the bottom until it oozes out the top bolt hole. Is that right? I removed both the bolts that I circled in red but nothing came out. I dont think the one to the right was needed to be removed, but figured I try to see if anything came out.
You know, I'm starting to question now if the "oil" I've seen dripping was simply just brake fluid from the master cylinder. The day I noticed the original puddle, I did have a slight leak of at the line exiting the MC and was bleeding the brakes, but it wasnt much. I notice a drop below the line again tonight so I tightened it some more.
I'd still like to flush the gear box out with fresh grease in the event that it wasn't brake fluid that I was seeing. Do I understand right that I remove both the bottom bolt (one on the left in my picture) and the top bolt (cant be seen in my picture, but directly above the previously mentioned one) and use the bottom hole for filling until it comes out the top?
No,
To flush the grease and put new in it needs to be completely dissembled. Those bolts (3) are there only to hold on the pre-load cover. There is a internal bushing and a pre-load assembly bolt that is part of the cover.
You can pump some grease in there but it will not force any of the old crap out. just lay on top for a bit until it gets homogenized with all the old grease.
Garbz
Garbz
No,
Garbz
Garbz
Needs to be taken apart cleaned and new grease put in. The old grease used is paraffin based and depending on how much heat it has seen will be caked in there. there is an upper internal seal on the steering shaft and no seal on the sector shaft
I just took apart 6 of these boxes trying to locate a good sector shaft.
Garbz
Garbz
