Antilock brake problem
Old Aug 24, 2010 | 08:48 AM
lionsteve's Avatar
lionsteve
While towing my trailer my front right tire will lock up if I have to do a an emergency type stop. This has happened twice now, leaving me with flat spots on tires. The trailer is heavy and is dropping the back end a bit. I am going to put another leaf spring in but was wondering if someone had an idea about this. The antilock brake light doesn't come on. I have a 2000 long bed, automatic with trailer brakes.
Steve
Old Aug 24, 2010 | 11:47 AM
itsjustdan26's Avatar
itsjustdan26
You may just need a new sensor. Make sure the connections are clean and clear too. It should be easy to find right near the front leaf spring. Also IIRC you may not be able to just replace the sensor, I think its built into the hub. Someone will speak up here shortly to help ya out.
Old Aug 30, 2010 | 10:25 PM
lionsteve's Avatar
lionsteve
Anyone else?
Steve
Old Aug 30, 2010 | 11:10 PM
BigAlsPSD's Avatar
BigAlsPSD
I hate to ask this but is your truck 4 wheel abs? All are rear wheel but not all, mine included has front ABS.
Old Aug 31, 2010 | 12:20 PM
lionsteve's Avatar
lionsteve
Not sure. How would I check?
Steve
Old Aug 31, 2010 | 06:42 PM
BigAlsPSD's Avatar
BigAlsPSD
You should have a sensor on top of the unit bearings on the front, that has a cable coming out. If no wiring is present, then more than likely you dont have 4 wheel ABS. Being a 2000 it had to be ordered with 4 wheel ABS, it was not standard until 2002 or 3 IIRC, this VIN decoder might help as well, I cant remember if its in the VIN or not though. https://www.ford-trucks.com/vin-decoder/index.php
darkgoku
Oct 18, 2011 10:02 AM
rob8210
1997 - 2003 F150
Jul 30, 2011 09:35 AM
kameronth
1978 - 1996 Big Bronco
Feb 7, 2004 12:57 AM
rickm5
Aerostar
Jun 7, 2002 11:42 AM
steve_
Bronco II
May 21, 2002 07:14 AM
