1978 - 1996 Big Bronco
Rear anti-lock?
Old Feb 5, 2004 | 01:23 AM
kameronth's Avatar
kameronth
Rear anti-lock?
So when I put the key over to the on position all the dummy lights come on like they are supposed to and turn off. One of them says rear anti-lock. When I first got my truck I thought it meant that I had anti-lock brakes so I slammed on the brake pedal and believe me, all I saw was smoke and tire marks. That kind of gave me a little clue that they are not anti-lock. So what does that dummy light mean? Mine is not on but I do always wonder.
Old Feb 5, 2004 | 01:50 AM
Kingersj's Avatar
Kingersj
actually u do have rear anti-lock breaks. that I believe is since our rear end are lighter (especially on pick-ups) so this should help prevent the rear from spinning around during hard breaking.
Old Feb 5, 2004 | 05:31 AM
RTM's Avatar
RTM
Mine light likes to light up when its wet outside.
Old Feb 5, 2004 | 10:18 AM
kameronth's Avatar
kameronth
Well I guess that is probably why it is called rear anti-lock. Thanks
Old Feb 5, 2004 | 04:41 PM
RTM's Avatar
RTM
The light comes while I am sitting still or driving braking or no braking. Its not just coming on while braking. I think the sensor gets wet and the water some how shorts the sensor out? The ligth will stay on and goes off when ever it feels like it.
Old Feb 5, 2004 | 10:32 PM
scotts88bronco's Avatar
scotts88bronco
i don't know if this will help but at one time my rear antilock light just stayed on. never had any braking problems tho. however i was removing some speaker wires and had to remove the threshold plate on the drivers side. there i saw a wire burned into. i spliced the wires back together with a connector and the light went out. easy fix for me.
Old Feb 6, 2004 | 09:15 AM
homerstud's Avatar
homerstud
Mine stays on all the time, and that is because the top of the sensor is broke off at the axle, I just put a piece of black tape over it.
Old Feb 6, 2004 | 05:49 PM
RTM's Avatar
RTM
I can't remember if mine started after I replaced the rear fuel pump or before. if it started after then I may have damaged the sensor. One day I will get under there and look. No breaking problems what so ever ewith my truck either.
Old Feb 7, 2004 | 12:57 AM
rlh's Avatar
rlh
I don't think the rear ABS is working on my 90. The light doesn't come on either. It comes on initially at startup and goes off after a second like its supposed to. I have hammered the brakes a few times and it didn't seem like the ABS did anything.
Is the rear ABS system on the Broncos a dog?
hilly7
May 6, 2015 11:57 PM
the_real_zekenator
Oct 30, 2013 12:37 PM
Hotairjunkie
Jun 26, 2013 08:40 AM
jmmartin
Mar 23, 2010 01:33 PM
qdessa
Nov 9, 2005 08:54 AM
