Electric trailer brakes
Should have only been a 'plug up' deal to a socket under the dash.
There is no direct interaction with ABS, normally.
ABS only would function when brakes are applied and a dissimular wheel rotation is detected by the ABS sensor.
The controller has an inertia sensor that functions to apply the trailer brakes and no effect on the truck's brakes.
You controller should have adjustment to change the application rate to the trailer brakes.
Good luck.
Good luck.
lostmybeer
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-14-2007 11:33 AM
SLAB
22
05-21-2005 02:28 PM
victorcharlie
09-19-2004 03:05 AM
1997, 2003, abs, brakes, car, electric, electrical, expedition, f150, ford, lights, tow, trailer, trailer2002, working
