Oil Change interval question
The problem with extended oil changes on the PSD is the HPOP. Unlike many other diesels, our engines use a high pressure oil pump to drive the injectors, at pressures reaching close to 3000 psi on a stock engine when under load or WOT. The HPOP has a shearing effect on the oil, reducing the lifespan of the oil. Different oils react differently in regards to the amount of shearing, as does driving habits. If you tow a lot, or have a heavy right foot, that oil will shear faster.
http://springerpop.net/F350/images/Blackstone1.jpg
But that's when I dump it, due to viscosity shearing.
Pop
I do agree with what you say about filtering alot more oil because of the amount of time the engine is running. But I am convinced that because of the amount of miles and time that I drive keeping the engine at operating temp prevents build up of particulates from the stop and go driving that so many people do these days.
If you look at it like this, anyone who has ever drove a car or truck with mostly highway miles and gets the motor up to operating temp for an extended period of time, gets longer and more usefull life out of there motor. it gives the engine time to disperse any moisture and keep sludge and contaminates to a minimal level.\
As opposed to someone who does alot of stop and go driving city driving etc where the motor never has a chance to clean out thus building up damaging sludge, varnish and other things. the life of that motor and vehical is always shorter than one that does mostly highway miles.
And of course a sample of the oil bye a reputable company would be the best thing to do. But from experience and working with and around diesel motors most of my life (yes I am telling my age) and being a mechanic as well I am more than comfortable with my decisions.
If you have ever heard of NORIA deals with how today lubricants break down less now days because of all the things that are put in it, as well as the refining process being so much better, that we really do get more and better usage out of our oils today than we used to. It is a proven fact that the death of almost all motors is from wear, metal shavings dirt, sludge etc.
So in that knowledge, clean oil, good filter, driving conditions, ie dirty enviroment, clean enviroment, hwy vs city etc. one has to make a decision on how often oil and filters need to be changed, as well as a good sample sent into get tested.
I know I said alot here, but I am just stating what works for me, because of my driving style, driving conditions, etc, I am more than confindent in comfortable with my maint schedual. Just food for thought, you wont believe this but here goes..... I have 8000 miles on this current oil change, and if you pull my stick and check the oil I can still see the hash marks on the dipstick thru the oil,,,, my oil is NOT black,,, how many of you out there can make that claim.....
Thank you for the great points you brought up, but we must all remember driving habits, and oil analysis is the best for oil change intervals
