Sponsored by: Real Truck
Tow/ Haul light Flashing
Old Sep 4, 2009 | 05:42 AM
Rambo76's Avatar
Rambo76
I have an 04 f350 with the 6.0 power stroke and on my way to work today the tow/ haul light started flashing and would continue to flash weather pushing the button or not. Any have any idea what is wrong?
Old Sep 4, 2009 | 09:08 AM
Deluxe05's Avatar
Deluxe05
It is an indication that some fault has been detected with the transmission or TCM (transmission control module). You could try getting a parts store to pull the codes to see what the fault is or take it into the dealership.
Old Sep 4, 2009 | 01:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Parts stores don't have the right tools to read Ford trans codes. You need a Ford specific scan tool, and they don't have them.
Old Sep 4, 2009 | 04:09 PM
Deluxe05's Avatar
Deluxe05
I had read that error codes could trigger the O/D light notification & the code would make it to the PCM in some cases, and that detailed transmission codes were only on the TCM. Being a former Ford engineer, I will bow to your expertise.
Old Sep 4, 2009 | 06:04 PM
tex25025's Avatar
tex25025
If there is a code that a generic code reader will pick up, it won't do you all that much code as it will be in very broad terms.
This is precisely why I'm a big advocate of either getting AutoEnginuity with the Ford License or use PT DIAG. I happen to use both, but AutoEnginuity would be the cheapest for just the average joe to use. The mongoose for the PT DIAG program would run you 400-500 by itself not including the software(biggest reason is that it also programs the modules as well, not just a code reader).
Old Sep 6, 2009 | 07:14 AM
Mark Kovalsky
Error code for the trans do flash the OD light. The code will be stored in the TCM. The auto parts stores do not have the Ford specific software to be able to read Ford transmission codes.
Old Sep 6, 2009 | 08:46 AM
Rambo76's Avatar
Rambo76
I got the code read b/c it through a check engine code and it came back as a selnoid? The shop that read the code said they won't touch a transmission ah! so he cleared the code and it drove fine for a day now the tow/ haul light is back to flashing and the truck isn't shifting right when I let off the gas completely
9218xz
Jun 10, 2024 12:06 PM
riverstroker04
May 3, 2017 08:46 AM
chuggen fuel
Nov 13, 2011 08:18 PM
JAYSF350
Nov 17, 2009 09:19 PM
balljoint
Feb 23, 2008 10:00 AM
