Fuel bowl drain
Aug 22, 2010 | 07:43 PM
Fuel bowl drain
Noticed my fuel/water drain is leaking again. I replaced it about three months ago and now it's leaking again. Is there a replacement other than oem that works better? I am going on a hunting trip soon and I don't want to be worrying about this as I will be 1000 miles from home.
Aug 22, 2010 | 07:46 PM
try the orings form guzzles a lot cheaper and better from what i have seen.
Aug 22, 2010 | 07:51 PM
Quote:
Originally Posted by
snakedoc
I'm not sure it is the o rings. It looks like it is leaking from the valve shaft.
Aug 22, 2010 | 07:58 PM
Aug 22, 2010 | 08:09 PM
Thanks for the info. I still have my old one. I will take a look at it. Any idea what size the third o ring is?
Aug 22, 2010 | 08:22 PM
Fuel Drain Valve Stem o-rings --- –013
Width 1/16"
Inside Diameter 7/16"
Outside Diameter 9/16"
Aug 22, 2010 | 08:28 PM
rbaker6336
Width 1/16"
Do you have a mil spec number for that?
Aug 22, 2010 | 08:32 PM
Checked the old on, sure enough there is a third o ring. I will try rebuilding it and replacing the other and then rebuilding it.
Aug 22, 2010 | 08:41 PM
crazymut
MIL M83248/1
Shore A: 75
Aug 22, 2010 | 08:57 PM
rbaker6336
MIL M83248/1
Shore A: 75
Thanks. I work with aircraft and may be able to get those o rings.
Aug 22, 2010 | 09:14 PM
I've had o-rings from Lowes in mine for almost 4 years
Aug 22, 2010 | 11:53 PM
Four years is about all you get from a BUNA O-ring. Ask me how I know, or read this:
https://www.ford-trucks.com/forums/8...a-o-rings.html
Get ready. Get the blue ones from Guzzle.
Last replacements you should ever need. They're fluorosilicone. Spec'd for military jet engines. Good enough?
Pop
Aug 23, 2010 | 07:42 PM
I have vitons in the glove box,One more set should be all I'll ever need
Aug 23, 2010 | 08:06 PM
I ordered two sets to keep in the glove box yesterday. One was going to rebuild the valve but I looked again today with the key on and found the filter top leaking. I checked that the other day but nothing showed. This time there was a steady stream. Put new filter, with squared edge oring in and leak is gone. No more beveled edge oring.
Aug 23, 2010 | 11:14 PM
SpringerPop
Pop
That's the one I put in a year ago. No more leaks. Better material than the yellow OEM Buna O rings and only cost a couple bucks more.
pickle40
Feb 7, 2015 11:35 AM
cedman
33
Feb 13, 2011 08:21 PM
kjstephe
Dec 18, 2009 08:34 AM
naseflorio
6.4L Power Stroke Diesel
Sep 23, 2009 12:45 AM
cl361
New Member Introductions
Jan 14, 2007 08:45 PM
1996 ,
1997 ,
2000 ,
2002 ,
73 ,
97 ,
bowl ,
drain ,
f350 ,
ford ,
fuel ,
kit ,
oring ,
powerstroke ,
rings
