A/C Compressor throwing sparks?
Old Aug 21, 2010 | 11:52 PM
HonkyTonkFronk's Avatar
HonkyTonkFronk
Hey all, I used this forum years ago with good results, but couldn't remember any of my information, so I'm here under a new alias.
The parents have a 2004 Explorer XLT, 4.6L, whose A/C has stopped working. Upon further inspection, I can see sparks and hear a grinding sound coming from underneath the engine block (which I believe is the compressor, forgot to check the engine diagram in the manual when I was last home) when the A/C is turned on.
Anyway, why would this be? Local shop has quoted $1400 to fix the problem, didn't get specifics from the parents. Any help would be appreciated. Thanks in advance.
-HonkyFronk
Old Aug 22, 2010 | 12:05 AM
aquanaut20's Avatar
aquanaut20
Disconnect the A/C clutch wire so it will freewheel.
The compressor is seizing, hence the spark shower, it will need to be replaced and the system serviced as small fragments will undoubtedly have found their way into the circuit.
Old Aug 22, 2010 | 12:13 AM
HonkyTonkFronk
Thanks for the quick reply! I'm not sure what you mean by "the system will need to be serviced" and "the circuit." What "system" and "circuit" are you referring to?
I've got zero experience with HVAC, but I've used Haynes manuals for years so if I know what to look up, I should be able to figure it out from there.
Old Aug 22, 2010 | 05:24 AM
V8Ranger302's Avatar
V8Ranger302
I think what he is say is there might be metal shavings in the a/c lines now. Thats not a good thing. The a/c system will have to be sucked out after you get the new pump on to ensure that there is nothing bad in the lines... I'm not sure you would have any metal shavings in the system, but you never know, it is possible. Sounds to me like the clutch and bearing is going bad. Like aquanaut20 said, disconnect the a/c pump by unplugging it so it cant turn on. It is going seize up soon so don't put it off to long.
Old Aug 22, 2010 | 06:23 AM
Moto Mel's Avatar
Moto Mel
It may just be that the clutch assembly has lost it's friction material or the magnet is going bad. A replacement is about $100.00 at Autozone. Only 1 bolt holds it on and it takes about 1/2 hour to replace.
Old Aug 22, 2010 | 08:53 AM
KhanTyranitar's Avatar
KhanTyranitar
If its throwing sparks, this is not a clutch problem.
$1400 is a lot of money, but let the pros handle this one, you need knowledge and know how to tackle AC, especially something big. Over half that cost is going to be parts. So lets see, about $700 in parts, plus another $400 in tools, you would need to spend at least $1200 to do it yourself, then you are stuck with a bunch of tools you might not use again. And without the knowledge and experience, you have a good chance of messing something up and have it fail sometime down the road.
Old Aug 22, 2010 | 12:45 PM
Moto Mel's Avatar
Moto Mel
It all depends on where the sparks are coming from. I have seen sparks coming from the clutch as it cycles. A more accurate discription is needed.
Old Aug 22, 2010 | 01:00 PM
Cuda_jim's Avatar
Cuda_jim
If the compressor turns freely then the clutch air gap has opened up beyond the magnets ability to pull the clutch plate all the way in, hence the sparks. The gap needs to be .015" (fifteen thousandths of an inch). Removing shims will fix it.
Old Aug 22, 2010 | 02:18 PM
dan8052's Avatar
dan8052
Here's my two cents from someone who refuses to take their car anywhere to be serviced. My '96 was throwing sparks from the compressor/clutch area. I could see the compressor stop spinning, power steering was gone and the car had almost no power to move. 3 shots of WD40 on the clutch and haven't had a problem since. That was about 8 years ago. Worth a shot! Good Luck!
Old Aug 22, 2010 | 05:12 PM
Moto Mel's Avatar
Moto Mel
WOW! Now that is what I call a low buck fix. It is definately worth a try.
Old Aug 22, 2010 | 05:37 PM
V8Ranger302
I wouldnt count on wd-40 to solve your problem. Not for very long.
Old Aug 22, 2010 | 05:58 PM
Moto Mel's Avatar
Moto Mel
8 years is a pretty good fix. If it was me I'd be happy with 8 months and then spray it again.
Old Aug 22, 2010 | 09:19 PM
HonkyTonkFronk
Holy cow. It will take me some time to get down this list and report back, but I'll keep you all updated. Your help is greatly appreciated!
-HonkyFronk
hackdog
May 21, 2014 07:23 PM
mebe2k
Escape & Escape Hybrid
Jul 1, 2011 05:53 PM
SleeprLegend
13
Apr 22, 2011 08:43 PM
Opossum
Nov 9, 2008 01:19 PM
T_Moss
Apr 25, 2006 07:29 PM
