351w Van Engine
Old Aug 21, 2010 | 10:27 PM
Country705's Avatar
Country705
351w Van Engine
Okay i have given up on the 347 stroker. I can buy an engine from a junkyard in ohio but I need to know if the a 351w out of a 1996 E150 Van will work with my mass air equipped computer. The engine has 114,000 miles and for everything they want 300 dollars. The only reason i am not jumping on it is that i am pretty sure that the van is obd2 were my truck is a obd1 with mass air flow. I want to swap in a 351w but i want a simple swap. while i got the engine out i plan on rebuilding the engine and the transmisson in my truck which is the 4r70w tranny. I am slowly gathering the parts but before i lay down the money for the engine i want to make sure it wont add more work on me.
Old Aug 22, 2010 | 11:33 AM
Conanski's Avatar
Conanski
There is no major difference between an OBD-1 and OBD-2 engine and the differences that do exist present no issue for your swap, the OBD-2 motor has a crank sensor that doesn't exist on the OBD-1 system so you can simply ignore it, same goes for the DPFE EGR sensor remove and discard it and use the old style EGR tube without the DPFE lines, and the 5.8 doesn't use a knock sensor so simply leave the connector hanging. Otherwise it's a direct plug-in on your engine harness, just be sure to use a 28oz/4R70w flexplate between the engine and trans and not anything else, do not use the 5.0 version or whatever comes with the donor motor.
Old Aug 22, 2010 | 02:39 PM
Country705's Avatar
Country705
so far here is the rebuild kit i have picked out for the 351w.
Federal Mogul MHP176-311 - Federal Mogul Premium Engine Rebuild Kits - Overview - SummitRacing.com
and here is the flexplate.
Hughes Performance HP5296F - Hughes Performance Heavy Duty Flexplates - Overview - SummitRacing.com
I plan on rusing motocraft parts for the ignition
and for exhaust i plan on using
Hedman Hedders 89270 - Hedman Street Hedders - Overview - SummitRacing.com
MagnaFlow 93312 - MagnaFlow Direct-Fit Catalytic Converters - Overview - SummitRacing.com
then have a magnaflow true dual stainless steel exhaust installed at an exhaust shop. i am hoping to get at least 350hp 380tq? is that unreleastic?
Old Aug 22, 2010 | 05:08 PM
Conanski's Avatar
Conanski
With the stock heads, cam, and intake.. yes. You'll get the TQ numbers no problem but the stock heads limit output to about 275hp even if the motor has enough cam and intake to get into the 350hp range.. which it doesn't.
And you need a 164 tooth 28 oz flexplate.
Old Aug 22, 2010 | 05:19 PM
Country705's Avatar
Country705
will a head upgrade change that and if so which head would be the best for my truck.
Old Aug 22, 2010 | 07:10 PM
Conanski's Avatar
Conanski
A head change will certainly help, you want something like Dart Iron eagles, RHS 180's, or AFR 185's.
camarokid81
15
Oct 27, 2021 08:24 PM
Ad01011
Jun 27, 2016 09:24 PM
camarokid81
Aug 2, 2009 04:01 PM
AZAV8
Engine Swaps
May 13, 2007 04:25 AM
gamehunter
17
Sep 7, 2002 07:47 AM
