towing
Old Aug 21, 2010 | 11:31 AM
derek4343's Avatar
derek4343
towing
anyone tow any loads in the 7000 lbs. weight up hills with a 5.4 ? how did muster them and did it scream the whole way up?
Old Aug 21, 2010 | 11:43 AM
Coskid's Avatar
Coskid
I have never had any issues while towing on any grades and I have towed something in this range maybe just shy of it but close. I have always turned off OD while towing even when its a small load and even grades.
Old Aug 22, 2010 | 08:20 AM
60DRB's Avatar
60DRB
I towed a 10K trailor from TX to AL with a 4.9 ('92 4x4 F-150). The engine and transmission are less of an issue than the brakes. Plan your stops well in advance to prevent overheating and/or jack-knife surprises. The engine won't scream unless you make it!
Old Aug 22, 2010 | 06:44 PM
Oldguy4's Avatar
Oldguy4
I pull a 25 foot Airstream that's in that weight range. It pulls up grades just fine at 3800 RPM. I don't call that screaming, that's right where the maximum torque is.
Old Aug 24, 2010 | 04:13 PM
osbornk's Avatar
osbornk
I do exactly the same thing and never a problem here in the mountains.
tseekins
2009 - 2014 F150
21
Sep 18, 2013 05:11 AM
freakville03
Apr 25, 2012 09:09 AM
2 stroke man
Mar 9, 2007 09:46 PM
kneeknocker63
All Things Towing
Sep 8, 2005 08:32 PM
kunder54
Oct 14, 2004 07:50 AM
