ZF trans oil
Old Aug 20, 2010 | 03:56 PM
thechief66's Avatar
thechief66
ZF trans oil
Hi guys, I'm new on here-I did a search on this but couldn't find what I'm looking for. Has anyone ever heard of running heavier weight oil in a ZF 5 speed manual to cure shifting issues? The truck shifts OK for short trips, but after driving for awhile & getting warm it'll grind when shifting. The factory spec is for regular Mercon ATF, but I thought some heavier oil might help. BTW the truck is a 96 F250 460 4x4.
Old Aug 20, 2010 | 04:20 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Never put anything in a ZF other than synthetic ATF.. Have you checked fluid level??
Old Aug 20, 2010 | 04:23 PM
thechief66's Avatar
thechief66
Fluid level is OK. I tried Motorcraft synthetic ATF (factory spec for 7.3's) and it was worse!
Old Aug 20, 2010 | 04:46 PM
bobbyjo9's Avatar
bobbyjo9
I run the Mobil 1 with good results
Old Aug 20, 2010 | 05:38 PM
strokin'_tatsch
Your problems are all the trans itself, not the fluid in that case. Does it grind on all upshifts? all downshifts? Only certain gears? The shift forks can cause shifting problems. Sounds like you either have fork problems or syncro problems. Think the clutch could be staying partially engaged once everything gets hot? Never heard of a temp related shifting issue on a manual trans.
Old Aug 20, 2010 | 05:55 PM
thechief66's Avatar
thechief66
My daily drive is about 8 miles each way, and I don't have problems going that far. If I go on a longer trip & the trans gets good & hot, you can't upshift 2-3 or downshift 3-2 without it grinding (unless I shift REALLY slowly).
Old Aug 20, 2010 | 05:57 PM
strokin'_tatsch
Shift forks most likely. The ZF in my diesel did that exact thing(except temp didn't make a difference) and shift forks took care of it. Thats about the only issue with the ZF if the shift fork material.. Well that and the input shaft size is too small. They snap behind our diesels with just minor mods. LOL
Old Aug 23, 2010 | 09:47 AM
thechief66's Avatar
thechief66
Well, I filled it up with Mobil 1 synthetic over the weekend. It seems to shift better, but I haven't had the chance to take on a longer drive to see if the grinding problem reoccurs. One thing I noticed is that the old fluid really smelled bad-it was just like an old burned up auto tranny.
Old Aug 24, 2010 | 06:29 PM
bobbyjo9's Avatar
bobbyjo9
Im guessin you must have had that in there a while. Dont forget to change the transfer case fluid too. sounds like you may be running the same mud in there too!
Old Aug 27, 2010 | 11:31 AM
thechief66's Avatar
thechief66
Well, I took it on a longer drive yesterday, and I still have the same shifting issues-when hot, it grinds upshifting into 3rd. If anyone has any ideas about why this only happens after driving 25-30 miles I'd love to hear them.
Old Aug 27, 2010 | 12:24 PM
bobbyjo9's Avatar
bobbyjo9
Id agree with strokin.. if your having heat issues I'd suspect the clutch is on the way out and not fully disengaging. The clutch fingers will weaken over time and loss there rigidity with heat. How many miles on the clutch?
Old Aug 27, 2010 | 12:28 PM
thechief66's Avatar
thechief66
Clutch was replaced 2 years ago with an OEM Ford unit-it's got maybe 20k on it and works fine.
Old Aug 27, 2010 | 12:32 PM
bobbyjo9's Avatar
bobbyjo9
sorry.. still not thinking straight.. you said third only? if it's just one gear I would suspect a sincro. Im not a tranny guy though so not sure on that.
Old Aug 27, 2010 | 01:38 PM
nstueve's Avatar
nstueve
x2 on bobby's post... I would find a local guy that works on trannys on the side and pay him to put new syncros in for you... probably do the shift forks at the same time... Might cost you $300-$500 for all the work to be done but It will shift like new!
Old Aug 27, 2010 | 04:18 PM
thechief66's Avatar
thechief66
A Ford technician told me this procedure for checking the condition of the synchros-
Drive truck about25-30 mph and slip shifter into neutral. Without pushing clutch in move gear shifter towards each foward gear gate 1-5 one at a time for 3 sec each. if the syncro is not worn out you should hear a whirring noise and feel some resistance this will burnish in syncro. if the syncro for that gear is worn out it will grind gear to gear.
I tried this test and got no grinding. That, plus the fact that it only happens when hot, and the truck only has 90K miles, leads me to question whether the synchros are really bad.
coreyallan01
21
Jan 19, 2015 11:59 PM
idt-572
May 2, 2014 04:41 PM
Pheadrus
Mar 31, 2014 03:13 PM
Pheadrus
17
Dec 22, 2013 02:09 PM
mrpontiac66
Jun 15, 2012 04:42 AM
