Shift points for ZF5?
Old Dec 19, 2013 | 10:50 PM
Pheadrus's Avatar
Pheadrus
I'm driving a 89 F250 4x4 7.3/zf5 190 miles home. It's been awhile since I drove standard and I've never driven a standard diesel. What are the common shift points? Anything to watch for?
Thanks.
Old Dec 19, 2013 | 11:07 PM
Macrobb's Avatar
Macrobb
You make full torque around 1600rpm, and, at least for me, it starts dropping beyond 2000.
If you upshift at 1600, it usually puts you around 1300, which works, but no real power.
If you upshift at 2000, puts you around 1600, so you're still in your power band(but, to me, sounded a bit loud).
Honestly, just play with it. These engines are great for lugability, and will produce power down to idle. I've cruised along in 5th at ~1100rpm before, but have to downshift if I want to accelerate or go up a steep hill.
BTW, if it's a stock truck, 60mph is about 2000RPM, which may sound a bit fast but is fine. I hear these engines can run just fine pushing the 3500rpm limiter, and hear about people running for hours that way, but /I/ would never do that.
Old Dec 20, 2013 | 12:07 AM
Pheadrus's Avatar
Pheadrus
Thanks for the info. It will be mostly Highway driving from MN up to Canada. So when I'm doing 60 leave it in 5th unless going up hills? When starting off in 1st, what's the ideal rpm to let the clutch out? Is there any tricks to the ZF5 like getting into 1st and reverse or is it basically like shifting a gas 5 speed?
Old Dec 20, 2013 | 12:17 AM
goose_ss4's Avatar
goose_ss4
I say keep it going till she won't pull anymore then shift. Listen to the motor it will tell you what it wants
IDIDieselJohn's Avatar
IDIDieselJohn
I always shifted my 90 F250 with 4.10's inbetween 1800-2000RPM.
You don't wanna lug it to much, that's hard on wrist pins in any engine.
Old Dec 20, 2013 | 07:05 AM
Gettysburg150's Avatar
Gettysburg150
Isn't there a diagram on the visor that shows recomended gear speeds? Maybe I saw that in the owners manual, I cant remember
Old Dec 20, 2013 | 09:18 AM
snowdog79's Avatar
snowdog79
I, too, shift at between 1800-2000 usually. 2000 sounds loud if you're not used to the diesel, but after a while you get used to the feel and sound. But anywhere between 1200 and 3000 is a good, useable range depending on load, etc.
Old Dec 20, 2013 | 09:25 AM
whiteboyslo's Avatar
whiteboyslo
Just remember the correlation between RPM and speed is dependent upon rear end ratio. I once saw someone post a PDF copy of some tech literature on the ZF. The only real warning I remember was to not spend prolonged time under 1000 RPM. Where I shift depends on how slow/lazy I'm feeling. Usually I wind her up to about 2K, but sometimes it's more like 1600. Either works, but with my non-WG Banks, the lower RPM drops me out of boost and can take a couple seconds to build after the shift. Not a huge deal if I'm feeling slow, but something to avoid when I'm trying hustle a bit or have a load.
Mike
Old Dec 20, 2013 | 12:17 PM
Pheadrus's Avatar
Pheadrus
Thanks guys. Great info. I'm driving it back tomorrow so hopefully everything goes o.k. But with the info you guys have given me I should be fine.
Old Dec 20, 2013 | 12:46 PM
hairyboxnoogle's Avatar
hairyboxnoogle
1500-2500 is where the power is. Keep it under 2k for fuel mileage.
Old Dec 20, 2013 | 02:01 PM
83capril's Avatar
83capril
I shift mine at 2k rpm. Seems to like it there the best. I have 4.10 gears and have had it well over 85 mph with no problem. It's like riding a bike at first you will wobble but it will all come back to you. Listen to what the truck is telling you and you'll know when to shift. Best of luck on the trip. Post pics up when you can. Looking forward to seeing the truck.
Old Dec 20, 2013 | 02:17 PM
Pheadrus's Avatar
Pheadrus
Will do. How do I post pics? I was going to when I was first looking at the truck but can't figure out how to. I didn't see a manage attachments tab? Also how many miles will the truck go roughly on one fill up? I'm driving 190 miles and will be going through some small towns that may or may not have diesel. So I want to plan my stops ahead of time based on fuel availability. It's a reg cab long box 4x4 and it will have a plow in the box. I don't know the ratio's yet. Just a rough ballpark will be good.
Thanks.
Old Dec 21, 2013 | 12:24 PM
tecgod13's Avatar
tecgod13
You should be able to easily get 190 miles on one tank.
I have a smaller ~16 gallon front tank and have no problem getting 200 miles before I fill up.
I don't really watch the RPMs when I shift, but I'm usually going to 3rd ~15mph, 4th ~25, and into 5th about 35mph. Thats with 3.55 gears.
Old Dec 21, 2013 | 01:17 PM
hairyboxnoogle
Get off idle much?
Old Dec 22, 2013 | 08:59 AM
Chevy_Eater's Avatar
Chevy_Eater
Upload them to Photobucket or a similar photo hosting service then post the links to the photos here.
Thanks.
