Where is this leaking from?
Old Dec 6, 2010 | 06:43 PM
Iallwork's Avatar
Iallwork
Ya! Jam rags down there and dry it up. Mine was the fuel pump. worked fine just leaked from the vent hole. Drove me crazy till I figured it out. Change the hoses with blue factory hoses as long as you got it apart.
Old Dec 6, 2010 | 07:44 PM
kawa's Avatar
kawa
Talking
You also might just try to tighten that banjo bolt just a tad. 1 1/4" wrench will get the job done.
Try this before ya tear everything apart.
Rog
Old Dec 6, 2010 | 08:18 PM
myred's Avatar
myred
If im not mistaken, hes pointing down in the section that i would think would mostly fill up if the fuel lines were leaking or something was wrong with the bowl. I just did this job, way in the back i thought it was mostly likely the fuel pump but hes shooting his light right down below the fuel lines,,, if its only filling it i would guess fuel bowl. I could be wrong , Do what they say and dry it up and shine down in the valleywhile someone starts it.,,, I couldnt see any of my fuel lines leaking but determined it was coming from underneath the bowl , i guess its the one you cant see or a scenser was leaking, Get the fuel bowl kit and start taking it apart ,,not a bad job
Mikey_23_ny1
Jul 7, 2015 08:40 PM
Snowseeker
Feb 28, 2015 09:59 PM
stcspiderman
Jan 20, 2014 11:44 PM
Caleb1
May 13, 2012 06:17 AM
JamesHajek
45
Apr 27, 2010 01:58 PM
