Boost & EGT Gauge Help
Old Aug 20, 2010 | 12:12 PM
jcobb124's Avatar
jcobb124
Exclamation Boost & EGT Gauge Help
Hey guys I was just curious if there was a specific place that worked best for the boost gauge vacuum line install and the probe location for the EGT?
Thanks in advance as always, you guys are awesome!!
Old Aug 20, 2010 | 12:15 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
I put the EGT probe in the drivers side manifold toward the back. I also teed into the MAP line for the boost gauge. Very simple to do. I think RIFF RAFF has a piece for right off the turbo on the boost guage.
Old Aug 20, 2010 | 12:34 PM
jcobb124's Avatar
jcobb124
TWG, could you dumb it down a lil for the boost gauge, ha ha this is my first diesel truck, and I am not that familiar with all of the goodies.
Sorry for my ignorance!
Old Aug 20, 2010 | 12:42 PM
twg1966's Avatar
twg1966
There is a vacuum line that runs from the turbo to the passenger side wheel well. On top of the wheel well is a container to which the line runs. I cut this line, installed a T and then ran my vacuum to the guage through the firewall on the driver's side of the truck. I know of several posts on this subject already, which is where I found mine. It is a really simple process. The hardest part is assembling the parts. Like I said earlier, RIFF RAFF Diesel has an item that would help in eliminating the need to cut the MAP vacuum line.
Old Aug 20, 2010 | 12:49 PM
Ponyboychris's Avatar
Ponyboychris
Look at this photo and the tee in the upper left (white tee and brass fitting) by the heater hose is the map line and where I tapped my boost gauge into.
Old Aug 20, 2010 | 12:57 PM
jcobb124's Avatar
jcobb124
THANK YOU, THANK YOU, THANK YOOOOUUUUU!!
Old Aug 20, 2010 | 01:02 PM
twg1966's Avatar
twg1966
Same way I did mine. I just don't have any pictures. Sorry.
Old Aug 20, 2010 | 01:54 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I think you mean the AIH Delete.
Riffraff Diesel: AIH Delete Plug
Old Aug 20, 2010 | 03:01 PM
cdrmotorsports's Avatar
cdrmotorsports
Check out this site for a little how-to info with some pics as well:
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old Aug 20, 2010 | 04:54 PM
Ponyboychris
That's the foo shizzle...
ocracokenc
Feb 2, 2017 09:46 AM
muskydawg
Jan 28, 2017 07:23 PM
Macmathews
17
Jun 1, 2016 07:14 AM
lvin4jc
Apr 19, 2015 04:25 AM
Lance_I
Jul 15, 2006 02:41 AM
