Thumping Sound
Old Aug 23, 2010 | 11:31 AM
superrman77's Avatar
superrman77
Originally Posted by AmericanMade
OP didn't say what year truck he had.... but I'm betting he hard an early bird.
There are several types of hub assemblies out there, between ABS and non-ABS hubs. However, the early one's have different hubs from the later years. Early hubs are MUCH more expensive than the later years (like double the money in some cases).
You can use the later hubs on the early trucks... just HAVE to change the front rotors (and pads because of the new rotors) to the later rotors because of the difference. So the OP probably put his old rotor's back on and that's the problem.
Ed's site mentions this in his Front Axel kit he sells.
And all of this I know because I've got an Early bird... and my Passenger side needle bearing is... on it's way out... causing the axle shaft to vibrate when i hit a bump. and then the next bump it will stop. If you grab the shaft you can move the shaft up quite a bit.
So I'll have to be digging into this soon... hooray!
You hit it right on. My truck was built in 02/99. I could have payed 500 for an assembly. I had no idea the rotor would be the problem. I just did my breaks, calipers,and rotors before winter. So what do I have to do?
Old Aug 23, 2010 | 11:49 AM
X JBM X's Avatar
X JBM X
You have 2 options.
A) You can order the correct part. My early 99 wheel bearing i ordered from Autozone for $200 shipped to my door, and it came with $20 in gift cards.
B) You can get 2 of the newer style wheel bearings (obvi 1 for each side) and also buy newer style front rotors.
Like you, I just redid my brakes, and was reluctant to buy new rotors all over again. Plus, if you switch it up, it could confuse people when doing future projects (since all parts on these things go by build date to separate early/late '99s).
So, I went with option A over B for the immediate cost savings. If you plan on having the truck for another 300k miles, option B would probably be the most cost effective for you.
Old Aug 23, 2010 | 12:03 PM
AmericanMade's Avatar
AmericanMade
Which hubs did you get for ~$200? Because looking at Autozoo's website the only one that is close to that price is one without ABS for build date TO 3/22/99. That would be the ones for early 99's.
But with and without ABS is the other factor I forgot to mention for the Hubs. Superduty's were standard with rear ABS, and it was an option for the front.
And for me any way, I'll be buried in my truck (only 78k on it now) so I'll be doing the whole front end when I do it. PartsGuyEd has a kit which makes it easy.
Old Aug 23, 2010 | 12:50 PM
superrman77
I paid 300 for mine and it was 3/99. I bought it at advanced auto. Mine has abs in the front. All that is just an extra plug in the assembly.
Old Aug 23, 2010 | 01:18 PM
X JBM X's Avatar
X JBM X
Wheel Bearing/Hub Assembly-Front | 1999 Ford F250 Super Duty P/U 4WD 8 Cylinders F 7.3L Turbo Diesel | AutoZone.com
Part # DL515075
Old Aug 23, 2010 | 02:08 PM
AmericanMade
x JBM x
How have those hubs been treating you? How long you have them? Do you do the whole greasing them through the ABS sensor? And what kind of driving do you do?
Just doing some research and curious about personal experience.
thanks!
Old Aug 23, 2010 | 03:48 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
My track bar bushings are shot and they make a similar clunk. Putting those in this week.
Old Aug 23, 2010 | 05:10 PM
X JBM X's Avatar
X JBM X
x JBM x
thanks!
I didn't grease them thru the ABS sensor, but I put plenty of grease everywhere else.
I haven't had it on for more than 500 miles yet, so I can't really tell you how it's been, other than the clunk I now have wasn't there prior to installation, but I can't say whether the 2 are directly related or not.
Old Feb 2, 2017 | 03:01 PM
gymbeau's Avatar
gymbeau
X JBM X
I guess it's a good time to ask again how those AutoZone bearings have treated you. It has been over 6 years now. Are they any good?
Old Feb 2, 2017 | 04:27 PM
BillyBob69's Avatar
BillyBob69
Looks like another thread resurrected...
I just completed a full steering and brake rebuild on my truck and still have a slight thump on the drivers side. I looked on the AZ site and see nothing for my truck. E99 w/o ABS front or back. Build date 10/98.
Old Feb 2, 2017 | 07:05 PM
gymbeau's Avatar
gymbeau
Part # DL515075 should work if I'm reading the description right. Mine doesn't have front ABS, but I plan to cut the wires if I get good feedback on the reliability.
Bugged
Oct 15, 2018 12:39 PM
DonnieMoran
All Things Towing
Feb 21, 2018 06:22 PM
SnowHiker
2004 - 2008 F150
Jan 31, 2018 07:18 AM
Jcof88
2004 - 2008 F150
Dec 23, 2016 07:31 AM
blue66tang95f150
15
Aug 11, 2016 07:18 AM
