Brake problem
Old Feb 21, 2018 | 12:56 AM
DonnieMoran's Avatar
DonnieMoran
Brake problem
Every time I hit my brakes I hear a loud whoosh of air. And I have to pump them 3 or 4 times to have any brakes. What is my problem or problems?
Old Feb 21, 2018 | 11:42 AM
nuctrooper's Avatar
nuctrooper
Hard to nail that one down....
Are you riding a bicycle or an F750? Are you talking about trailer brakes or truck brakes? Air brakes? You're posting in a ford forum about towing conventional trailers.
Old Feb 21, 2018 | 03:11 PM
DonnieMoran
Brake problems
I guess the rest of my post didn't make it. Every time I hit my brakes I hear a loud whoosh of air and have to pump the brakes 3 or 4 times to have any brakes at all. Even then they are weak and the pedal almost hits the floor. Any suggestions would be appreciated.
Old Feb 21, 2018 | 03:13 PM
DonnieMoran
Brake problems
Just the truck brakes. 1983 ford f100
Old Feb 21, 2018 | 05:22 PM
Clubwagon's Avatar
Clubwagon
The whoosh sound is likely the brake booster. Sounds like the master cylinder is bad. Check the base where it fits against the booster and see if its wet with fluid.
And check your brake fluid level.
Old Feb 21, 2018 | 06:22 PM
DonnieMoran
Thanx. Will check those out.
Dcope17
All Things Towing
19
Sep 14, 2018 10:54 AM
devino246
Nov 18, 2011 07:48 PM
StarTrash
Jan 15, 2008 06:13 PM
