What Time Is It?! M Clock Keeps Changing!
Old Nov 11, 2017 | 07:08 AM
Bugged's Avatar
Bugged
Any of you guys have this problem?
My truck is a 2017 F250 4x4 FX/4 Superduty with the 6.7 PSD. Sync-3.
The digital clock on the center screen seems to want to keep changing to a time that is six hours earlier than the local time. I reset it and it sticks for as long as I keep the truck on, but then when I shut off and re-start, it resets itself back to the incorrect time.
Any ideas?
Old Nov 11, 2017 | 07:33 AM
rwtdct's Avatar
rwtdct
Might have to do with your GPS settings.
Old Nov 11, 2017 | 08:55 AM
Sleepyguy's Avatar
Sleepyguy
Mine just started doing the same thing. Turning off the update seems to work but then you don't have an updated clock.
Never had this problem prior weird.
Old Jun 16, 2018 | 08:05 PM
SC_Mike's Avatar
SC_Mike
My 2017 F250 Platinum just started doing to today. Anyone find a fix?
Old Jun 16, 2018 | 08:15 PM
senix's Avatar
senix
can you configure the clock based upon EST/CST/Mountain time zones?
Old Jun 16, 2018 | 08:34 PM
SC_Mike's Avatar
SC_Mike
I have it set to auto configure. I believe it works off of the GPS. Not sure if you can set to to a certain time zone.
Old Jun 16, 2018 | 08:48 PM
senix's Avatar
senix
Then your GPS is suspect and may need replaced.
Old Jun 16, 2018 | 10:25 PM
brandontolentino's Avatar
brandontolentino
Do you have NAV? If not I don't think there is a GPS module in the Sync system so it won't get the proper time if the GPS time sync is selected in the options. I just turned it off on mine and it's been fine ever since.
Old Jun 16, 2018 | 10:46 PM
SC_Mike's Avatar
SC_Mike
im not 100% sure if I have nav, but I think I do. I’ve never used it, but it’s a pretty loaded platinum. I’ll check it out in the morning and see if that’s the issue. Thanks for the tip.
Old Jun 17, 2018 | 06:00 AM
senix's Avatar
senix
It will most likely be the module that needs replaced.
Old Jun 17, 2018 | 09:53 AM
SC_Mike's Avatar
SC_Mike
turns out I have Nav. I just reset the clock again. Hopefully it holds. If not, I’ll have to get it looked at when I bring it in for my first oil change.
Old Oct 14, 2018 | 10:50 PM
Race Red F-250's Avatar
Race Red F-250
Any update to this? Is there a fix or setting to keep time from changing?
Old Oct 14, 2018 | 11:27 PM
3rdfordtruck's Avatar
3rdfordtruck
Mine too.
Mine was doing this and driving me crazy.
I did did a complete reset and then downloaded the update.
It it seems to have fixed the problem.
Hope this helps.
Old Oct 15, 2018 | 12:39 PM
bridge's Avatar
bridge
Sick 'n Tired
Mine started doing that, then the GPS started messing up, then the sync system started to get real laggy...turned out to be an APIM failure. Replaced under warranty.
Busa 1 Dave
Dec 16, 2018 09:11 AM
Tawn
Mar 12, 2018 05:56 PM
Scott4343
Jun 8, 2016 06:59 PM
Mike1tx
Apr 24, 2009 07:11 AM
Flozzie
Feb 4, 2003 01:59 PM
