78' F150 issues
Old Aug 19, 2010 | 08:41 AM
Aaron-71's Avatar
Aaron-71
Originally Posted by JP66
Thanks for the info guys.
I will get a chance to work on it later this weekend.
I will also post some pics later too.
I would consider editting your profile and stating your location in your "about me" information.
That way you can get advice from those around you, and it's a very easy way to make friends and close contacts on this website.
Another way to find your brethren is to join what's called a "Chapter" on this website.
If you scroll to the top of this page, you'll see the task bar with the following from left to right:
"Home" "Forums" "Models" "Galleries" ... etc
In "Forums" there is a "Chapters" option. I highly suggest you go into the chapters section of this website and find your state/province so that you can join your own local group for help finding:
stores, parts, deals, friends, contacts, etc... The list goes on...
Chapters has been very helpful for many of us because it means we can come even closer together as a community online.
Old Sep 1, 2010 | 05:59 PM
JP66's Avatar
JP66
The click-click issue was fixed. As many noted, it turned out to be a faulty battery. I exchanged the battery for a larger new one. My original problem is still present. I am not able to turn over the engine.
So far, I have replaced the battery and the battery cables, the starter and the starter cable, the starter solenoid, the fuel filter and the fuel pump, and the spark plugs and the coil. Many of these things weren't needed to be done, but I figured I would swap some old stuff out for new stuff. It has all been fairly cheap actually. I plan to swap out the fuel tank, sender, and lines as well, just to have newer stuff.
I poured some gas into the carb, but it still wont start. What should I check next to get her started? I will check for spark too, as well as to make sure the new pump is getting fuel to the carb.
I have a feeling the carb may need to be replaced. Is this a diy job?
Thanks!
Old Sep 1, 2010 | 09:48 PM
Dskeet6's Avatar
Dskeet6
check the voltage regulator
J.McConnell
16
Jul 29, 2014 05:50 PM
deputydog03
53
Nov 5, 2013 03:41 PM
El Padrino
17
Mar 9, 2013 08:25 PM
1scott
1983 - 2012 Ranger & B-Series
Dec 16, 1999 02:12 PM
