Keyless entry - adding
Old Nov 3, 2014 | 10:44 PM
  #31
mntlshok's Avatar
mntlshok
Hey would a 1996 f250 have the connector even if it doesn't have the module? I can't find either one.
Old Nov 4, 2014 | 03:35 PM
  #32
presidentsdad's Avatar
presidentsdad
I would imagine that every F250 has the wiring in place (provided it has power locks), but may lack the module. Mine is an XLT trim and must've already had the module from the factory and someone likely lost the FOBs over the years. So all I did was buy a new FOB off of ebay and then program it.
Old Nov 4, 2014 | 08:17 PM
  #33
mntlshok's Avatar
mntlshok
Thanks for the reply. I have looked all over and don't see it or the connector. It should be by the door chime correct?
Old Nov 5, 2014 | 07:39 AM
  #34
presidentsdad
IIRC, the panel is under the steering wheel and the module pictured in post #24 is just to the right of the wheel.
Old Nov 5, 2014 | 07:59 AM
  #35
bduemig's Avatar
bduemig
You are asking about a 1996 which is after they went to powerstroke (as far as diesels are concerned, so there may be a difference from year to year.
My 94 XLT has power locks but no key FOB's. I contacted Ford for a build sheet and when I got it is said it did not come with remote locks. But when I removed the panel under the steering wheel, there was the module. I ordered two FOB's, programmed them and they worked!
I assume in my model year, the power lock module is the same as the remote lock module so it may be in all models with power locks.
Just noticed I allready posted this in an earlier post! Must be getting old!
Old Jul 20, 2016 | 11:49 AM
  #36
Talllcool1's Avatar
Talllcool1
So my son just bought a one owner '96 with 91k original miles, wanting to add keyless entry. Truck has power locks, etc, but no module under the dash. Found this on the web, 1994-1996 Ford F150 Keyless Entry Module Connector - Body Electrical - Motorcraft 94-96 F150 Keyless Entry Module Connector - 5311-05157886 - PartsGeek. Believe it or not, an employee at Parts Geek could not tell me if this was just the connector, or module with connector. Does anyone know?
Also, while looking under the dash, I did not see any empty connectors to plug a factory module in to. Should that be obvious, or is it buried behind something else?
Old Jul 20, 2016 | 12:15 PM
  #37
Freightrain's Avatar
Freightrain
Welcome to the forums.
That I would bet, by the description is ONLY the connector. Not the module.
I've wanted to put keyless on my recent '95 but figure I'll buy a remote start system and use that instead.
Old Jul 21, 2016 | 11:40 AM
  #38
444dieselrod's Avatar
444dieselrod
Despite what this thread says NOT every truck has the wiring. I know for a fact as I've looked at many and oddly only 1 had the wiring and the module. The module and connector are right behind the dash cubby above the gas pedal. If you lay on the floor add look up you will see it, IF it has it.
You can added it but it's alot of wiring.
Old Jul 22, 2016 | 12:45 AM
  #39
fordf250sdguy's Avatar
fordf250sdguy
Cant program key fob
I have a 03 f-250 electric doors. Everytime i do the 8 turns it never signals its in the program mode plz help i just bought 2 key fobs
Old Jul 22, 2016 | 08:16 AM
  #40
Freightrain
Welcome to the site. You need to go here:
1997 - 2003 F150 - Ford Truck Enthusiasts Forums
As that is the forum for your year truck. Likely more help there.
Old Sep 29, 2023 | 03:51 PM
  #41
Scooter65's Avatar
Scooter65
1st Gear
Hi, I have the exact same truck. I have a question. We just bought our truck and it started having trouble with jerking when it went into second and 4th gear. It is an automatic. Our mechanic said it was from the remote keyless module that was blowing the fuse out. It drives fine now. My question is, I found a remote keyless module that fits a mustang with the same age. Ours is a 1995. It has the same 15k602 -AC number on it. Will that work in the F250? This was for bduemig, but anyone who has any knowledge is welcome to answer.The truck is a 95 Ford F250 extended cab.
Thanks for any advice.
Omega Man
Jun 15, 2015 03:47 PM
ssaa426cuda
Oct 18, 2010 10:51 AM
nasdaqsam
Nov 29, 2005 03:50 PM
Mil1ion
Electrical Systems/Wiring
Dec 1, 2003 05:34 PM
endroad_06
1978 - 1996 Big Bronco
Oct 22, 2003 12:00 PM
