Stock coil
Old Aug 16, 2010 | 10:42 PM
94MustangGT's Avatar
94MustangGT
Originally Posted by Cory281
It's OBD 1. I can get it checked though, I'll try that.
Your local auto parts store should sell a Ford OBDI digital code reader for around $30, and are worth it.
They come with a nice manual, and it should pay for itself the first time you track down an issue.
Is it MAF? If so, the MAF senor filament can get dirty over time and cause poor performance. A Q-tip and rubbing alcohol do the trick.
Old Aug 17, 2010 | 10:31 AM
skyfox10's Avatar
skyfox10
Well the truck feels like it has lost power, so I'm trying to figure it out. I've given it a tune up with in the last year, the air filter is good and the fuel filter was changed 6 months ago.
does it feel like it's lost power in the low end, high end, or throughout the rpm spectrum?
Old Aug 17, 2010 | 11:16 AM
TexasGuy001's Avatar
TexasGuy001
I agree about the code reader. I have the Equis Innova 3145 that has the digital read out so you dont have to count beeps and flashes.
Old Aug 17, 2010 | 10:10 PM
Cory281's Avatar
Cory281
It feels like on the low end mostly, if I punch it, it will go just fine. Just cruising down the freeway it feels like its lost power.
I'm going to check for vacuum leaks tomorrow and maybe get it ran for codes.
Old Aug 18, 2010 | 08:23 PM
Cory281's Avatar
Cory281
I put a new PCV valve in the truck today, it has never had one on and has 155,000 miles. Then I noticed a cracked up vacuum line. I'm not sure what it's for, but it's about a inch and half long and goes to this unit that's mounted on the passenger side of the throttle body and goes into the throttle body. Anyone know what this thing is? It has a couple of other lines coming off it, I can take a pic if anyone doesn't know what I'm talking about.
Anyway the truck seems to be running better, at least around town it feels like it has some power again. The true test is when I get it on the freeway and see how it does when it's up to speed.
kylant
Dec 24, 2016 02:33 PM
landers0440
Apr 29, 2016 11:11 PM
jim milewski
Mar 17, 2016 12:51 PM
Winning Windsor
1997 - 2003 F150
Jul 11, 2015 10:06 PM
Quadiquizm
Dec 14, 2002 09:55 PM
