'04 with rear end shutter
Old Aug 15, 2010 | 04:22 PM
Joeymt3's Avatar
Joeymt3
My dad's '04 has 85,xxx miles and has been doing the rear end shutter for probably the last 15,xxx. We are curious to know if we can convert the LS to a open and save the cost of replacing the clutch pack.
thanks
Old Aug 15, 2010 | 05:37 PM
Oldguy4's Avatar
Oldguy4
I'm sure it can be done. He could get an open unit from a bone yard, same ratio of course with fewer miles maybe, and change it out. I would be sure to replace the axle bearings too, There are probably containates in the oil.
Old Aug 15, 2010 | 08:52 PM
Joeymt3's Avatar
Joeymt3
I was hoping to be able to do it with out pulling the carrier and resetting the gears. also, keeping cost low. the truck is 4x4 so he is not too concerned about going to an open diff.
Old Aug 16, 2010 | 12:16 AM
boots6868's Avatar
boots6868
do you think the friction modifier might need re-done? I forget what miles ford recommends fluid change out. sounds to me like either your gear oil is low (probably not) i think i would not want to lose my ls. I would try re-filling with fresh gear oil and modifier i think they call for 4 oz. Ive got the opposite problem in my 08 sd mine wont lock up half the time. Im guessing your getting chatter on sharp turns, that is usually an indicator of not enough modifier. you guys didnt change out fluids at some point and not add the modifier did you? just an idea
Old Aug 16, 2010 | 06:49 AM
Coskid's Avatar
Coskid
I don't think Ford recommends changing the axle fluid but I would do it somewhere in the range of 60-80k on the truck. It certainly wouldn't hurt to try that before looking fr a new axle.
Old Aug 16, 2010 | 05:06 PM
Djack04F150XL's Avatar
Djack04F150XL
You could change the fluid, and the friction modifier. I usually add Lucas oil treatment mine @ a 50/50 ratio with the gear oil. It's worth trying unless your unit is toast.
Old Aug 16, 2010 | 09:03 PM
Joeymt3's Avatar
Joeymt3
that is a good idea, i'll try a fluid change. thanks
Old Aug 16, 2010 | 11:08 PM
Lime1GT's Avatar
Lime1GT
My 02 wasn't making the normal shudder sound but more a rubbing noise. I added 1/2 bottle of friction modifier and noise is gone.
I pretty sure under severe service, Ford recommends diff fluid changes. What climate isn't severe service? Especially mine with temp extremes from -40F to 100F.
1977cutcher
2004 - 2008 F150
53
Mar 22, 2018 09:31 AM
PeteNel
Jan 4, 2017 10:32 AM
ODGuy
1997 - 2003 F150
Aug 21, 2016 08:48 PM
captainstabbin
2004 - 2008 F150
16
Feb 10, 2016 08:10 PM
Lumberbrok
Apr 12, 2005 06:35 PM
