upfitter switches
Old Jun 30, 2011 | 04:45 PM
  #31
Part-Timer's Avatar
Part-Timer
IIRC, page 112 of your owner's manual will give you the amperage rating and wiring color code for each upfitter switch. The switches have ratings of 10 to 25 amps. However, the pass through wires are thin - like 16 ga.
Even though the upfitter switches are already relayed and have relatively high amperage ratings, I wouldn't connect them to anything that draws a lot of current using the pass through wires (unless maybe you use two of the pass through wires in parallel or use a seperate relay on the engine side of the connection).
Brian
Old Jul 2, 2011 | 11:57 PM
  #32
uscgmkcret03's Avatar
uscgmkcret03
Mounted my back up lights to the holes on each side of the receiver hitch, up n under so the are protected, dont know how many lights I've crunched backing into stuff when they were mounted under bumper. used switch # 3, 10 amp
Old Jul 9, 2011 | 05:13 PM
  #33
Mike Varner's Avatar
Mike Varner
Is there a way to wire one of the upfitter relays around the ignition switch? I would like to mount some convenience lights in the back that I can turn on and off without the key on.
Old Jul 15, 2011 | 09:07 PM
  #34
lakedweller's Avatar
lakedweller
I put my upfitter switches in today. What a bitch finding the connector under the dash to plug them into. You have to be a contortionist to get to it. My neighbor is a little smaller than I am and he was able to plug it in for me. They work just fine....
Old Jul 18, 2011 | 08:05 PM
  #35
cabindoc's Avatar
cabindoc
I have attempted this twice and had to stop. For 1 reason I am 6'4" 280 lbs and you need to be smaller and most recently, I cannot find where I am supposed to mount the relay box. Can anyone tell me where it goes?
Old Jul 18, 2011 | 08:27 PM
  #36
lakedweller
Scott
It mounts right behind the headlight switch. Pull that panel off and the panel under the steering wheel. It mounts vertical. I to am 6'4" and 300 lbs, and the plug is impossible to see up on the right side where the steering wheel goes thru the firewall. You must remove the blank plug that covers the upfitter plug.
Old Jul 18, 2011 | 10:13 PM
  #37
kper05's Avatar
kper05
Not the greatest pictures but maybe this will help out.
Connector from upfitter fuse box to BCM (I think it's the BCM).
Upfitter fuse box mounted near the parking brake.
Old Jul 19, 2011 | 05:44 AM
  #38
cabindoc's Avatar
cabindoc
Thanx! that helps. so in the second pic, the view is from the floor looking up and the box mounts say between the steering column and the side directly behind the headlight switch?
Old Jul 19, 2011 | 09:15 AM
  #39
lakedweller
That is right and it goes in vertical, the mounting brackets are there. That's the easy part reaching the connector and snaking the cable over are another story.....
Old Jul 19, 2011 | 11:12 AM
  #40
my996duc1's Avatar
my996duc1
Also to get some more light into there you can pull off the side panel on the end of the dash.
if you want to use the factory electrical grounding bolt then the above mentioned stuff is the easy part.
Ford could have made it so much easier if they would have put the grounding bolt on the other side of the metal brace/bracket.
I would bet alot of people just add another bolt somewhere for the ground and call it done.
Old Nov 5, 2011 | 11:49 AM
  #41
dkingjr45's Avatar
dkingjr45
i have a 2011 6.2 flex fuel (gas) f350 with upfitter switches. i found the blunt wires under the dash labeled aux1,2,3...., but the 4 blunt wires under the hood, (pass through wires) are different colors than the aux wires under the dash. are they supposed to be?
Old Nov 5, 2011 | 12:51 PM
  #42
mrjc's Avatar
mrjc
The four wires (pass-through) are just 4 colored wires Ford put there for an owner to use for whatever. If you chose four colored wires, cut them to about 4ft lets say, got under the dash and drilled a hole in the firewall, passed them through and tucked them away on both ends, you would have them there for anything you wanted to run a wire through from inside the cab to inside the engine compartment. 2 are thick 2 are thin for various loads. It was a nice thought for commercial uses so the customer wouldnt have to go poking holes in thier nice truck. The upfitter wires are usually connected to these. I used my 2 of them for Fog lights and a camera and are hooked to the wires for upfitter switches 1 and 4. Tis confusing, but having the wires there poked through professionally is a good thing for adding electrical mods
Old Nov 6, 2011 | 06:28 AM
  #43
airbornewarrior's Avatar
airbornewarrior
Thanks for info on the pass thru wires, me and my brother punched hole in wire boot. Guess we should read the directions.LOL
Old Nov 6, 2011 | 08:36 AM
  #44
DesertDan's Avatar
DesertDan
I did the same thing, but I didn't wire this through the upfitter switch. The PIAA backup lights came with a switch that allows the driver to choose between OFF/ON/BACKUP ONLY mode. I've only had it for a week, but this seems like it will be a handy setup.
Old Nov 11, 2011 | 05:51 PM
  #45
elemakule's Avatar
elemakule
So the pass-thru wires have nothing to do with upfitter switches? Are any of them heavy enough gauge to connect my ham radio to the battery? I'd fuse them inline under the dash.
