Windshield and Windshield Accessories Question
Old Aug 14, 2010 | 11:59 PM
CalebJns's Avatar
CalebJns
Guys, I have a '78 F100 Custom, SWB, 2WD, with a 351W and C6 transmission.
Question 1: Curious if other years Windshields are compatible with the '78 (i.e. any 73-79's)? As well as the rear windows?
Question 2: Windshield Washer Sprayers....is there any way to Change them to a different style? Currently mine are the JET stream, and only spray in two very DIRECT spots...I have looked at the aftermarket sprayers...I would prefer to have some that fan out...is there an aftermarket type that work well? or how do you get under the vent area where the sprayers are located? All the aftermarket sprayers I have seen require the base to be screwed on, and I would need to get under the vent area (not sure what the correct term is, but hopefully everyone knows the area I am talking about)
Any help and information is greatly appreciated!
Old Aug 15, 2010 | 12:29 AM
650's Avatar
650
73-79 windshields are all the same. I believe for the aftermarket sprayers are supposed to just mount onto the hood? I think it would be near impossible to put one under the cowl.
Old Aug 15, 2010 | 12:54 AM
HIO Silver's Avatar
HIO Silver
Here are a couple of options to install more sprayers:
1. Get a couple/few from an early Mustang. Drill a hole on the face of the cowl to insert the metal tube, secure with a screw to the cowl, and tee off to them. Note that you'll have to aim through the cowl's slots.
2. If you're okay with drilling the hood. The sprayers from 85-92 VW Golfs (and their variants and maybe newer too) have two sprays on one head and can be aimed by (gently!) inserting a needle into the orifice and aiming it to the areas of choice.
Old Aug 15, 2010 | 09:04 AM
CalebJns's Avatar
CalebJns
I would prefer to not drill into the hood, they need to come up with a sleeve to fit over the OEM sprayers, and convert them to a fan style or dual sprayers per side...
Old Aug 15, 2010 | 09:08 AM
limegoldf100's Avatar
limegoldf100
Windshield is the same from 67-79. The rear window is the same from 73-96 and also for 97-98 F-250 and above heavy duty.
Old Aug 15, 2010 | 09:54 AM
CalebJns's Avatar
CalebJns
What's everyone's thoughts on sliding rear windows in the dentsides? I don't have A/C, so I am looking at it for air circulation purposes...but would probably go with a tinted/smoke color...
Old Aug 15, 2010 | 10:20 AM
mark a.'s Avatar
mark a.
Get the tinted single window slider, I don't think they still make the 2 window sliders but if they do and you have the choice I'd get the single.
Old Aug 15, 2010 | 10:34 AM
650's Avatar
650
Are you sure, because my brother has a slider from an 86 and I have one from a 79 (according to the person at the show) and the groove for it to go into the window rubber is like a 1/4 inch taller than the groove out of the 86 which is almost flat.
Frdtrkrul
1997 - 2003 F150
Jul 20, 2014 09:43 PM
1985 Bronco
13
Jun 25, 2014 11:10 AM
Volkelrunner74
Sep 23, 2012 02:08 PM
terceslil
Sep 9, 2009 09:56 PM
kameronth
1978 - 1996 Big Bronco
Jun 4, 2005 06:53 PM
