brake issues
Old Aug 14, 2010 | 10:14 PM
crazer42's Avatar
crazer42
brake issues
this only happens when i brake real hard! which is rare but if i apply alot of pressure to the brakes my pedal will all of the sudden loose pressue and go in, then become firm again near the bottom, is this normal?
Old Aug 14, 2010 | 10:30 PM
twags6's Avatar
twags6
That sounds like the ABS is kicking in. Do you loose stopping power when it happens or feel like the truck isn't stopping like it should?
Old Aug 14, 2010 | 10:45 PM
mueckster's Avatar
mueckster
Mine, on occasion, does the same thing. ABS activating.
"During the 4WABS operation, the driver may feel a pulsation in the brake pedal, accompanied by a slight up and down movement in the pedal height. In addition, a mechanical noise from the engine compartment may be heard. The pedal effort and pedal feel during normal braking are similar to that of a conventional power brake system." Quote from my Ford manual.
Old Aug 14, 2010 | 10:47 PM
twags6's Avatar
twags6
My headlights also dim for a split second when the ABS kicks in. The controller uses a lot of juice to pump the brakes. Ever notice that?
jleo
Apr 4, 2010 01:29 PM
61 uni
May 23, 2009 06:01 AM
afonda
Dec 26, 2008 01:56 AM
wvbogger
Jan 31, 2008 01:09 PM
