1973 restoration
Old Jan 2, 2011 | 11:52 AM
  #121
sdully88's Avatar
sdully88
I wouldnt have powdercoated the frame and suspension...unless you live some where that they dont use road salt or you have no plans of driving in the winter. Powdercoating has no primer so once it chips the moisture gets in and rusts it out. Also once chipped it peels off in long strips...look at any late model vehicle with a subframe or a late model truck. Ford used a [powder coat on the suspension parts and have probably made a fortune off of people in the midwest selling spring shackles, shock mounts, radius arm brackets, and whatever else gets rusted out. I'm sorry if I came across like I was bashing your decision as I didnt mean to I am only trying to inform you of my experience and what I have learned in talking to a couple of guys that powdercoat and listening to my parts guy at the Ford dealer tell me how many suspension brackets they have sold due to the coating getting chipped and peeling and not having primer underneath.
Old Jan 2, 2011 | 07:19 PM
  #122
grinnergetter's Avatar
grinnergetter
Well..SDully its a little late now. As I said before it aint seeing salt after all the body work involved. I've chipped mine in several places and it does not seem to be a problem. I hit it with some touch up primer and paint where it has been damaged. I also did it to a quad frame many years ago and it was bulletproof. Serious woods riding. I guess time will tell.
Mocked up the trans today and figured out the crossmember. Might be a little overkill but it is not going anywhere. Cab on tomorrow night.
Old Jan 4, 2011 | 07:43 PM
  #123
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
I would powder coat it also. As we can see by your thread no powder coat does no better!! Nice work!!
Old Jan 4, 2011 | 08:51 PM
  #124
bobwires's Avatar
bobwires
Powdercoating that falls off was either not done properly, or REALLY hammered by rocks. The whole idea is it's not just a coating, it's soaked into the metal. Powdercoat is a fantastic primer - you can shoot paint on top of it for an incredibly long lasting finish, and it would be repairable (blendable topcoat color)
Old Jan 5, 2011 | 05:28 PM
  #125
grinnergetter
CAB ON!!!!!! Got my MSD box and Borgeson steering shaft on the way. Notice the bucket so I can sit in the truck and go Vroom,vroom
Old Jan 5, 2011 | 10:13 PM
  #126
Austin26372's Avatar
Austin26372
Gosh, that is sooooooooooo perdy!
Old Jan 5, 2011 | 10:44 PM
  #127
JustBlaze's Avatar
JustBlaze
Man that's looking sick. What's holding the radiator up?
Old Jan 12, 2011 | 10:12 AM
  #128
grinnergetter
Dont know what I did with the "CAB ON" photo. But anyway its on and we mocked up the fenders so we could drill holes for the cab.
Decided to shut up and make my own linkage for kickdown and throttle.
Dont know why I just didn't do this in the first place. The thread for the linkage that goes from the carb to pedal lever is a mystery to me. It's not 10x24 or 12x24...huh.
Shift linkage had to be shortened.Does anyone make a special puller to get shift linkage off or on the column???I am sick of wrestling with these darn things. What is the magic method or tool.
MSD is almost in and we got about 10 inches of snow today so I get to spend the afternoon in the barn. SWEET
Borgeson steering shaft is in. Steering column spline was flared somewhat on the end and was a major pain to get on without breaking something.
Old Jan 12, 2011 | 12:46 PM
  #129
jay54f100's Avatar
jay54f100
Your project is comming along so nice.
Old Jan 12, 2011 | 02:48 PM
  #130
Old Crank's Avatar
Old Crank
That is one sweet project you have on the go. The only problem I have with it is the drool collecting on my keyboard.
Old Jan 12, 2011 | 08:56 PM
  #131
bobwires's Avatar
bobwires
this is a very fine automobile.
Old Jan 13, 2011 | 08:12 AM
  #132
wyckedcombo17's Avatar
wyckedcombo17
Holy shed! That thing is really coming along! Looking great!
I probably missed it but what carb are you running? If it's one of those truck avengers I'd be interested in knowing how it works out for ya
Old Jan 13, 2011 | 04:07 PM
  #133
bigdaddys76's Avatar
bigdaddys76
That damn shift rod is a mf'er
Put the nylon bushing in the shift arm first then grease up the hole the rod goes thru, rod pops right in with a LARGE pair of channel locks
Old Jan 13, 2011 | 09:20 PM
  #134
grinnergetter
I should invent something for the shift linkage and make my millions.
Old Jan 24, 2011 | 11:05 PM
  #135
grinnergetter
Got the 460 running and broken in which went without incident. Had a minor float adjustment on the Edelbrock carb but no big deal. Modified the trans cover for the transfer case and put in the floor mat and seat.
Need something other than an milk crate to sit on.
Need drive shafts and hydroboost....we rollin soon.
