1973 restoration
[quote=grinnergetter;9219156]Truck was a camper special originally and will be going on a 73 highboy 4WD frame.
Tabs have been welded to frame so I dont have to mess with making even more holes in the bed.
quote]
I am not familiar with camper special beds but I`d assume they would be the same (short of the toolbox). On my 78 Explorer bed onto my highboy we had to make brackets for the bed but since one of the crossmembers was at a different location on the frame (third bed crossmember back) we had to drill holes in the frame and and make the third mount back be about 1/4 of an inch lower than the rest so it would sit correctly with the frame. I just cant imagine there wouldn`t be a difference in the beds crossmembers like mine on your truck, but then again maybe because it is a camper special bed it is different. Good luck with it though. Keep up the good work.
quote]
asuming you have front drums on your 1973 4x4 chassis you wont be able to use the proportioning valve.. either way i still want them brakets, they are 2wd specific. can you post a pic of the brake/hub assemblie and how much do you want for them.. thanks joe
I'm going with discs on the front(dana 60)...I looked today and I'll bet your after the brackets that are about as tall as the calipers. ie what the caliper attaches to.
I'll get a pic tomorrow and post it as soon as I can...I have no idea what they are worth but your welcome to them for a fair price.
before you waste any time. can ou measure the distance between the top two and bottom two bolts "the ones that mount it to the spindal. i heard there were diferant bolt patterns for the braket, i wanna make sure these are what i need. we will figure a price from there, any idea what you want??
#28
