Air Assist Steering
Old Aug 13, 2010 | 08:38 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Air Assist Steering
Did Ford offer Air Assist Steering on the F250-350 trucks in the eighties.
Thanks
-Enjoy
fh : )_~
Old Aug 13, 2010 | 10:31 AM
bghnkinf250's Avatar
bghnkinf250
Pretty sure they did not, are you thinking of adding it?
Old Aug 13, 2010 | 12:56 PM
Franklin2's Avatar
Franklin2
No one ever had air assist did they? They had hydraulic assist, but I would think air would be too "springy". You can't have the wheels hit something and bounce against a air cylinder.
Old Aug 13, 2010 | 06:41 PM
bghnkinf250
It looks like an upgrade for military rides and big trucks.
Old Aug 13, 2010 | 06:45 PM
arctic y block's Avatar
arctic y block
I have ran Ford 9000's and corn binders with air steering. Was a bitch to turn around in a tight spot as they was always out of air and the brakes would set till ya built up enough air to finish the turn around.
Old Aug 14, 2010 | 10:54 AM
Festus Hagen
Methanoholic
No, An argument between my neighbor and I, he says his 88 F350 came from the factory with Air Assist Steering, Even stated he had to buy repair parts from Ford!
I told him it was an aftermarket kit ... He insists it's factory Ford!
What confuses me is the fact that the truck also has Hyd power steering!
I have had several big rigs with Air assist, when they first came out they sucked, but after a year or two they improved a lot and became a very good alternative and work awesome on very little air.
-Enjoy
fh : )_~
Old Aug 14, 2010 | 04:14 PM
cadunkle's Avatar
cadunkle
I call shenanigans on the air assist steering. If it existed, on light duty trucks no less, there will be pictures and documents floating around. Can anyone dig anything up?
Old Aug 14, 2010 | 08:08 PM
Franklin2's Avatar
Franklin2
I doubt it on a small truck also. The only reason they seem to consider air operated equipment on a larger truck is because they usually have a air compressor already there for the brakes. I have seen passenger side "electric" windows that were air operated as well as air operated wipers on the larger trucks with air brakes.
dieselsubmariner
Nov 23, 2014 10:47 PM
CraigerF100
13
Dec 23, 2012 09:44 AM
Kalve
General Automotive Discussion
Apr 23, 2010 10:36 PM
Scott Thomas
May 6, 2006 04:59 AM
johnorser
26
Oct 7, 2003 09:31 AM
