i have a 66 f-100 with 352 has a carter fuel pump with canister with markings 0-2208 i'm trying to find out if the pump is rebuild-able and if so where can i get a rebuild kit
This Carter 0-2208 fuel pump is not original to the truck, it's an autoparts store replacement. Go to NAPA, give the partsguy the Carter number, see if they have a kit for it.
The original Carter fuel pumps for your application would have been marked:
Something right up my alley I dealt with...and played heck getting the right part...
Contrary to what many will say...part stores especially...there were 2...TWO variations of the fuel pump used on the FE engines in 65...and I suspect 66..one IS serviceable...the diaphram can be replaced...obvios to the eye as it has many small bolts securing the 2 halves together.
The other type, and the one much harder to find, is the non servicable crimped together unit...no bolts at all...Original units will have a 4 digit number stamped into the mounting flange area...on mine its on the lower rear surface as installed on the engine...thus not easily viewable on the engine...There were a few different variations available..
Mine has a code of 4007 stamped in it...and I still have it...the original will also have Carter cast into the body of the pump as well...
If you have an inline fuel filter, you can use the later D2TZ part number as those dont have the fuel filter can below it as original...cheaper too I would suspect as well.
