5 to 8 lug conversion
Old Aug 11, 2010 | 02:48 PM
Barkin 40s's Avatar
Barkin 40s
what would i have to do in order to convert my 79 1/2 ton d44 front end from 5 lug to 8 lug? i have a d70 rear and i want to be able to have the same lug rims all the way around the truck. any ideas?
Old Aug 11, 2010 | 03:07 PM
86pullerf350's Avatar
86pullerf350
It may be easier to just switch out the whole axle and upgrade it to a dana 60 which is an 8 lug axle. It would be stronger and take more of a beating, if thats what you plan on doing with it.
Old Aug 11, 2010 | 03:18 PM
Barkin 40s's Avatar
Barkin 40s
na lol i dont have the money to match gears and build new brakets for the new axle and all, i aready have cromoley axles on my 44 so im keeping it i just dont like the mix match lug pattern. i know it can be done and ive read other threads about it but its not clear to what exactly i need to do this swap. do you or anyone else know the diameters of the 8 lug rotors vs. the 5 lug ones? but yea if i had the money id definately go d60 front
Old Aug 11, 2010 | 08:11 PM
Barkin 40s's Avatar
Barkin 40s
anyone? ttt
Old Aug 13, 2010 | 12:16 AM
Barkin 40s's Avatar
Barkin 40s
is there another topic page that this thread would be better on?
Old Aug 13, 2010 | 09:18 AM
Wyowanderer's Avatar
Wyowanderer
Just taking a stab at it- try markwilliams.com; ask them if they make a conversion. Also currie.com
Old Aug 13, 2010 | 10:07 AM
Barkin 40s's Avatar
Barkin 40s
i checked those sites they dont make anything like that, but im talking about home made stuff even if they did make a conversion it would probably be more than $500. but im just trying to figure out all the parts i need to swap over from a d44 HD to my normall straight axle d44
Old Aug 13, 2010 | 10:40 AM
bghnkinf250's Avatar
bghnkinf250
Try this site:
A write-up on performing an 8-lug swap on a TTB Dana 44 front axle for Broncos and F-150s: Off-Road.com
Old Aug 13, 2010 | 10:46 AM
bghnkinf250
Or this for straight axle (not sure if there is a difference):
Sterling 10.25 and 8 lug swap [Archive] - FSB Forums
Old Aug 13, 2010 | 03:58 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
Try posting this in the off road forum on here.
Old Aug 13, 2010 | 09:35 PM
Barkin 40s's Avatar
Barkin 40s
alot of good info on those links thanks
Old Aug 13, 2010 | 11:21 PM
Greyf100's Avatar
Greyf100
should just be:
rotors
calipers
outer knuckles
outer axle shafts
wheel bearings
ball joints
1972fordhighboy
13
Oct 12, 2019 04:33 AM
whisler
Sep 11, 2013 03:11 PM
BradyCouchman
Jul 16, 2010 08:19 PM
mattjensen
Apr 24, 2009 04:28 PM
1ole4d
May 29, 2002 10:50 PM
