New MLPS, Ignition Switch, Ignition, Solonoid, still no start... help!
Old 08-10-2010, 04:20 PM
BDFD's Avatar
BDFD
BDFD is offline
I've replaced all that and I still cannot turn the key to start the truck (1996 351). I really didn't mind replacing everything as I'm sure it all needed to be replaced eventually anyway. I can turn the key on and jump the solonoid and the truck will fire.
Does anyone have any guidance on how to further troubleshoot this? I hooked up a test light to the one small wire on the starter solonoid and it did not light up when I turned the key.
THe truck acts like it wants to start (dash lights dim, etc.) when I turn the key but I get nothing, not even a click. What do you think?
Old 08-10-2010, 04:52 PM
leavy20's Avatar
leavy20
leavy20 is offline
no click at the solenoid. and its been replaced with a new one? how does the under hood relay look? for the starting system.
Old 08-10-2010, 05:00 PM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
Bummer... in the Power Control Box under the hood, is the big starter system fuse ok? also check the park/neutral safety switch
Old 08-11-2010, 10:02 AM
jas88's Avatar
jas88
jas88 is offline
Are your reverse lights working properly? You may just need to adjust the new MLPS.
Old 08-11-2010, 02:25 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
Also, when you replaced the ign switch did you leave the two fasteners loose and try adjusting it a little up and down the column?
Old 08-11-2010, 02:57 PM
Nealcrenshaw's Avatar
Nealcrenshaw
Nealcrenshaw is offline
Sounds like the NSS. Check it for voltage as you have someone try to start it.
Old 08-11-2010, 05:25 PM
BDFD's Avatar
BDFD
BDFD is offline
Thanks for the input guys. The MLPS is essentially the neutral safety switch from what I understand and has already been replaced.
Haven't looked at any relays under the hood yet. This is the intel I'm trying to gather.
Last time I checked (this past weekend) the fuses were all good to go except the 30A horn fuse which I replaced.
When I put the new ignition switch in I tried to start the truck just from the switch itself and no dice. Powered up ok, the rest of the truck acted like it started (dimming lights, blower, etc.), but no action from the starter.
These parts were sourced at NAPA so I'd like to think they are quality electrical components.
Lemme check the reverse lights, relays. I'm headed out there now.
Old 08-11-2010, 05:40 PM
Nealcrenshaw
THE NSS and the MLPS are entirely two different items. Hence the different names!
One is a switch and the other is a sensor.
Old 08-11-2010, 05:50 PM
Nealcrenshaw
OH wait.... we're talking about the E4OD,You may be right!
Old 08-11-2010, 06:23 PM
BDFD's Avatar
BDFD
BDFD is offline
jas88 is today's winner. I put the new MLPS in and knew it probably could be adjustable by the way it looked but when I put it on its range of movement was nil.
I loosened it a bit, turned it that one hair it would allow and bam. Fired right up. Again, thank you very much.
Old 08-11-2010, 09:32 PM
Lonzo's Avatar
Lonzo
Lonzo is offline
If you get under there with a flashlight, look closely at the MLPS. There is a line that lines up with a mark (marked "N" on mine) when the lever and transmission are in neutral.
Old 08-11-2010, 10:17 PM
86F150302's Avatar
86F150302
86F150302 is offline
Glad you got it.
But do what Lonzo said or it will be shifting funny.
Grainmaster
16
03-18-2013 12:55 PM
larrylass
08-31-2012 11:22 PM
larrylass
08-30-2012 12:26 PM
larrylass
Electrical Systems/Wiring
08-13-2012 11:35 AM
fordpdx
08-28-2007 08:43 PM
Quick Reply: New MLPS, Ignition Switch, Ignition, Solonoid, still no start... help!
