they fit BUT theres gonna be an unsightly gap between the panel and the wing panel if you are putting it on a pre 2008 its because the 2008 and up door panels ar slightly taller, but if You are putting them in an 2008 truck I'd say Buy em' The OEM look is still the cleanest in my books, the tweeter size for the oem one is 1.5 inches...
thanks blue. they are going in a 2004, but i have 2008 door panels coming that i hope fit.
I'm In the midst of doing the 2008 Door panels in My 2005, I'll have a write up on it soon, but a couple of side notes for you, Wiring for the Main window and lock switches are completely different, there will be som re- pinning and re-wiring involved, I have yet to tackle that in my swap, there is also the inner "door handle cups" that need to be changed, will post more pics and info when swap is complete ....
