$450 buy it now turbo kit
1993 1994 FORD F350 TURBO USED (INDIRECT INJECTION): eBay Motors (item 110454610198 end time Sep-02-10 11:10:59 PDT)
I talked to the owner and he said for 450.00 he would include the other stuff with the turbo.
up pipe, down pipe, cross pipe, valve covers, intake hat, pedestal and oil feed tube.
Still good deal though.
it is a direct bolt on. you would only need the rubber grommet for the oil drain (the one that he has will be hard as plastic) and you will need to just bolt everything up and get an air filter for it. it took me about 6 hours to do mine, you will need to unbolt the body and lift it though to clear the uppipe between the firewall and the engine/bellhousing. only downside is higher egt's. you would have to get a egt gauge. better mpg, more power when towing and driving hills. if you just flat land it, then your not going to see any benefit from a turbo. they dont start to spool and throw boost until you load it down.
I'm already there so where is my 3" elbo and DP? Oreo I see a couple psi if I accelerate almost moderatly and thats with the bent up down pipe if you get on it boost comes in instantly these turbos spool off idle. Of coures your IC will mask the boost to a point not hurting power same amount of air going in the air is just more dens so it has less presure for the same amount of air.
