Motor rattling
Motor rattling
My truck rattles when going up hills. The higher the rpm,the more it rattles. It sounds like a heat shield shaking. Also, when I accelearate on a flat road, I hear this very light knocking sound.
Motor has 190 000 km and is due for an oil change. Spark plugs and plug wires have been replaced. Engine sounds good when I rev it. No abnormal sounds. So, what would be my issue? Carbon build up?
Allright, I am gonna tank some 91 tonight and see if that fixes the rattling sound at high RPM.
If that is the fix, that means my motor is gummed up with carbon and such. Is there any motor cleaner I can buy that I can supply dump in the gas tank? I really don't feel comfortable using see foam. I've never done it.
I could find this at a Ford dealer you think?
my truck with a 3.0 will get to pinging slightly. I will bump up an octane grade for awhile and it goes away, after 3-4 months I have been able to put reg octane back in again. Its looking right now like its almost time for a bump up in octane again as the summer is coming in and makes it worse.
Top Engine Cleaner
Bg products 44k performance enhancer cleaner | eBay
No you get it in a can and connect it to a vacuum line, shut the engine off let sit for 15 minutes then drive the hell out of it. I have no idea if Ford sell this or not. If you want a good cleaner to put into the gas tank look on ebay for BG 44k, a good second best is Techron.
Top Engine Cleaner
Top Engine Cleaner
JAMES1952
13
08-12-2017 03:33 PM
offshore1
2009 - 2014 F150
03-29-2014 02:44 PM
