97 with a problem
Old Sep 16, 2012 | 11:40 AM
quesey's Avatar
quesey
97 with a problem
Well swaped motor's and it's better but i still have a problem maybe someone can help with.
Before with the old motor it would run but had a miss(burnt piston) it would fight to rev above 2000 so i thought it was in the motor.Now with another motor in it.It still is doing the same thing runs good just fights to rev above 2000.?If sitting still and i floor it it will run up to 2000 and sit there and after 5 or 10 sec it will rev up to 3000 and sound good. let it come back to idle and it does it agian.Now nothing is the same on motor's i left all sensor's and HPOP on motor when i droped it in.
Anyone have an idea?
Thanks john
Old Sep 16, 2012 | 11:42 AM
quesey's Avatar
quesey
oh it had a code po470 but cleared it and drove it and it did'nt come back
now just the p1111
Old Sep 16, 2012 | 01:09 PM
fordpride's Avatar
fordpride
Have you check to see if that truck has a chip?
I'd blow the fuel lines back to the tank with air.
Have you tried the other tank?
Old Sep 16, 2012 | 01:23 PM
quesey's Avatar
quesey
No chip
Just have fuel in one tank right now.but i may stick some into other tank and try that.i'll get my pump out and pump some into front tank.
Like i was saying it will rev on up just takes some time sitting still and dont want to mess something up driving it like that.
It's just odd that both motor's are doing the same thing and nothing was swaped over from the other motor. Tryed unpluging map and it made it a little worse. I swaped the one from my dually before i pulled the motor out and it did'nt help. I may try it with this motor an see.
I did get the OD light to quit flashing lol.
Thanks john
Old Sep 16, 2012 | 01:25 PM
quesey's Avatar
quesey
Oh and i do have a Y pipe and boot's i can send if your still needing them.
Old Sep 16, 2012 | 04:46 PM
quesey's Avatar
quesey
Well changed out the IDM and it seems to run better.
maybe it's just that it don't have a chip in it YET
It just don't run like my dually lol.
But i have noticed that when its laging it's smoking blue and smell's like fuel
Thanks john
Wesmith
Jun 4, 2018 12:25 AM
JAMES1952
13
Aug 12, 2017 03:33 PM
77f250weos
Jun 30, 2014 02:05 AM
redneckfordman1
13
Feb 22, 2012 09:05 PM
Bt Doctur
Oct 18, 2004 05:24 PM
