My son just drove my truck 96 Ranger 4.0 5 speed manual on a trip for 2 1/2 hrs and he says that the a/c was working just fine for 20 minutes and then he had no air flow coming out any vents. he stopped for a few minutes to get a bite to eat and everything started working again then after about 20 minutes again no air flow out the vents. I'm thinking that there is a relay that might be overheating and needs to be replaced. any ideas?
Pop the hood & make sure the wires to the blower motor aren't burning up. If they are, you'll need a new blower motor. Also check for power & ground w/ a test light while it's turned on but not working.
well I've checked the truck out and have found nothing wrong. the a/c works fine with me but i only drive it to and from work about 15 to 20 minutes. I checked the wires and relay that's behind the right headlight and seems to be OK but does get a little warm.
Check for evaporator icing. If the evaporator turns into a big block of ice, the blower will spin but no air will move. Tell-tale is a giant puddle of water under the vehicle half an hour after it was parked post-failure. Additionally, there may be visible frost on the evaporator outlet lines and the accumulator. Usual cause is a slight undercharge or a cycling switch that is stuck closed.
Well talking to my son again he says that the fan motor was running but nothing coming out the vents so the evaporator may have froze up.
