A/C blower problem
Old Aug 9, 2010 | 12:32 PM
Eaglefixer's Avatar
Eaglefixer
A/C blower problem
My son just drove my truck 96 Ranger 4.0 5 speed manual on a trip for 2 1/2 hrs and he says that the a/c was working just fine for 20 minutes and then he had no air flow coming out any vents. he stopped for a few minutes to get a bite to eat and everything started working again then after about 20 minutes again no air flow out the vents. I'm thinking that there is a relay that might be overheating and needs to be replaced. any ideas?
Thanks
Old Aug 9, 2010 | 12:40 PM
DLP Performance's Avatar
DLP Performance
Pop the hood & make sure the wires to the blower motor aren't burning up. If they are, you'll need a new blower motor. Also check for power & ground w/ a test light while it's turned on but not working.
Old Aug 11, 2010 | 03:36 AM
Eaglefixer's Avatar
Eaglefixer
well I've checked the truck out and have found nothing wrong. the a/c works fine with me but i only drive it to and from work about 15 to 20 minutes. I checked the wires and relay that's behind the right headlight and seems to be OK but does get a little warm.
Old Aug 11, 2010 | 09:56 AM
DLP Performance
Hmmm... You might want to get a relay. Either replace it & see what happens or wait until it quits & swap it out on the side of the road!
Old Aug 11, 2010 | 10:57 PM
projectSHO89's Avatar
projectSHO89
Sigh...
Check for evaporator icing. If the evaporator turns into a big block of ice, the blower will spin but no air will move. Tell-tale is a giant puddle of water under the vehicle half an hour after it was parked post-failure. Additionally, there may be visible frost on the evaporator outlet lines and the accumulator. Usual cause is a slight undercharge or a cycling switch that is stuck closed.
Old Aug 12, 2010 | 04:37 AM
Eaglefixer's Avatar
Eaglefixer
I just put a new clutch cycling switch on the day before this happened
Old Aug 12, 2010 | 07:30 AM
projectSHO89
I learned a long time ago (the hard way) that "new" does not always equal "good". Any part should remain suspect until proven to be good.
Old Aug 12, 2010 | 09:04 PM
Eaglefixer's Avatar
Eaglefixer
Originally Posted by projectSHO89
Sigh...
Well talking to my son again he says that the fan motor was running but nothing coming out the vents so the evaporator may have froze up.
badger2196
Sep 10, 2024 09:14 PM
UncleRedBuck
Jun 9, 2016 10:39 PM
Tenderpaw
Jul 7, 2011 04:55 AM
pete315
Jun 8, 2010 07:42 AM
Neal 97 250
22
Sep 16, 2009 08:37 AM
