I'm kinda aggravated that my engine runs in the 170's range all the time according to my scan gauge. International says its normal temp is 192 to 219 and at 176 the cap system kicks in and sets the idle at 1400 does that mean I need a thermostat from international or buy the 203 and I love my ford don't get me wrong but if they would have designed a instrument panel that told you actual readings a lot of down time could be stopped sorry for my rant
Yeah, i did get my coolant reading its usually a few degrees from my oil reading which is in the 170's range if im going 65 for a while its around 190. from the numbers that IH gave me its jus telling me that something is wrong, i donno what to do at this point
At the same speed and with the ambient temp in the 90's my coolant temp gauge reads about the same, 180-190* The truck seems happy in that range.
My truck runs in the 170's also (oil temp). Seems normal to me.
Hum ok well that's good to know if I wanted to install a actual oil and water temp / oil pressure gauge where would I have to put the senders and how would you run lights to them
