Stock 7.3 PSD Upgrades
Old Aug 8, 2010 | 09:31 PM
Borddoger's Avatar
Borddoger
I am new to the list and new to Ford PSDs..
I am purchasing a 2002 F250. Can I get pros and cons for this engine and some performance upgrades you would do immediately... if any
Thanks on advance
Jason
Also on a side note... anyone know the specs and towing capacity?
Old Aug 8, 2010 | 09:35 PM
Borddoger's Avatar
Borddoger
Guess I should say the truck only has 79000 miles on it...
Thanks
Jason
Old Aug 8, 2010 | 09:38 PM
Borddoger's Avatar
Borddoger
Thanks
Jason
Old Aug 8, 2010 | 09:40 PM
brownie83's Avatar
brownie83
first open up the intake with a 6637 filter...search "6637" basically you get rid of the bad stock air box and get a better filter. also open up the exhaust with a 4 or 5" turbo back system...then look into gauges and a chip after all that. from then on ...good luck you will get a serious case of powerstoke mod syndrome...PMS
check out riffraff diesel for you parts...he is a sponsor and a great guy who is always ready to help.
good luck and great score on the truck with so low miles
Old Aug 9, 2010 | 06:03 AM
SGnAZ's Avatar
SGnAZ
First off-Welcome to FTE.Where are you buying the truck,Dealer,private party,Joe Schmoes automart?I would change out all the fluids,if it hasn't been done already,that way you know everything is fresh.Some people like the 6637,others don't,say it has too much whistle,I won't run one,I'm going to run the AIS from Ford,a bit pricey,but it was made for the truck.I don't care for chips and tuners,just my opinion.The owners manual will give you the specs and towing capacity.I've towed close to 10k with no problem.Good luck,you'll love the truck.
Old Aug 9, 2010 | 08:08 AM
Borddoger's Avatar
Borddoger
Buying the truck from my cousin... No doubts he kept up on the maintenance... he did say he had a problem with the rear end a couple years ago and got it replaced. Said he hasn't had a problem since.
Thanks for the info. Looking forward to this truck.
Jason
Old Aug 9, 2010 | 08:34 AM
kccatpower's Avatar
kccatpower
welcome to fte. how are you planning on using the truck? i would check over all the maintenance items first. this will help you get to know your new truck. then i would put in a set of guages. alot depends on what you want to do and how much you want to spend? good luck and enjoy.
Old Aug 9, 2010 | 09:49 AM
green 69's Avatar
green 69
Welcome to FTE
Congrats, on your purchase, and welcome to FTE. like most have said if in doubt change fluids check brakes, and go over your rig.
I like the 6637 filter it does give a slight turbo whistle and it can be found at your local napa store. Gauges of some sort are really good to have even if you don't go with any chips, power add on's. Exhaust is a good choice to help move the extra air you introduced into the engine now move it out.
Old Aug 9, 2010 | 08:41 PM
BobbyDiesel71's Avatar
BobbyDiesel71
where are you located in Il Jason?
Old Aug 9, 2010 | 09:40 PM
jirwin's Avatar
jirwin
Welcome to FTE. The amount of information on this site is staggering. Before you buy anything do a search on the 7.3 forum. There is someone who will give you good feedback. X2 on Clay from RIffraff. He is kinda like a super hero as near as I can tell. Have fun with your truck, but make a budget. lol
Jason DiManna
Jun 12, 2013 11:43 AM
Sn0wMan
15
May 16, 2007 10:10 AM
Jason T
Nov 12, 2004 10:17 PM
fishmanndotcom
Offroad & 4x4
Feb 13, 2004 11:10 PM
